Opinion - which single engine hull is the fastest >
Old 11-09-2008 | 08:58 AM
Default Opinion - which single engine hull is the fastest
Winter (and broken Merc outboard again) has me down and I keep thinking about putting together a project.
I want a single engine boat (V-bottom) 24' or greater that would make a good race boat as well.
I'm looking for the fastest hull Hp for Hp.
Yes, my project will be diesel but that has no effect on the question, I need to determine what hull I would start with? It doesn't have to be a boat currently in production, I would start with a used boat that runs great now so I have a baseline to work with.
There are soooo many out there now Activator, Phantom, Fountain, etc, etc which is faster?
Joe Gere
HabanaJoe is offline
Old 11-09-2008 | 09:47 AM
BAJA WILL's Avatar
Registered User
Wow, your asking a open winded/opinionated question. Fastest single engine hull would probably have to be a 26 Velocity, however not by design, by weight, theyare about 1000lbs lighter than anyone else. However I would suggest a 27 Fountain, or 29. a couple clicks off from a Velocity butbuilt much stronger.
I am sure you will get plenty of opinions
BAJA WILL is offline
Old 11-09-2008 | 09:49 AM
berns29scarab's Avatar
27 or 29 Kryptonite !!
berns29scarab is offline
Old 11-09-2008 | 09:51 AM
I have ever seen write something that was not full of opinion? LOL
Does anyone have speeds of these boat with a 500hp?
Krypto, Act, Vel, Beak, Bat, etc?
Old 11-09-2008 | 09:57 AM
TeamSaris's Avatar
Driver-441
Racer
We ran a 27 kryp race boat to about 80 with a stock 500 efi.
TeamSaris is offline
Old 11-09-2008 | 10:07 AM
howard made the fastest single engine v, so they could be in the running
Perlmudder is offline
Old 11-09-2008 | 10:09 AM
I think I heard it from a pantera owner first....... Its not how fast you go, but how well you go fast
TexomaPowerboater is offline
Old 11-09-2008 | 10:23 AM
TEAMBAJA's Avatar
http://www.mcleoddesign.com/
TEAMBAJA is offline
Old 11-09-2008 | 12:38 PM
Gordo's 25 Active Thunder ran 80mph with a sealed 500HP. It was a light lay up boat, but also had a full cabin.
Griff is offline
Old 11-09-2008 | 12:40 PM
Pantera24's Avatar
BINGO !!
I actually say ... "It's not how fast you go but how fast you get there"
Pantera24 is offline
