fuel lines
Old 11-09-2008 | 04:32 PM
ak
Default fuel lines
Hey guys,
I am in the precess of changing my fuel lines from 3/8 to 1/2,removed the hose,fitting and the pickup tube today from the tank,i found a valve in the fitting on the tank that i assume is an anti drain back valve which probaly is not good for horsepower and fuel demand of a not stock engine,and also there a steel screen on the bottom of my pickup tube.
My question is that i read somewhere that you should remove the valve from the fitting and the screen also,is this true?I am changing that fitting to a bigger one anyways so i wouldnt be using it,but what about the screen???I think i was having a fuel restriction at higher rpm but it would keep pressure though???????
ak is offline
Old 11-09-2008 | 07:05 PM
When I did my system I used a bigger pick up with no screen.
whoya is offline
Old 11-09-2008 | 07:24 PM
Mr Gadgets's Avatar
Charter Member #601
ak,
that drain back is USGC stuff. I think there is a way around it, by putting a shut off valve in line?? Not sure. But if they board you, be sure there is enough stuff on top of it so they cant find it..
Just kidding. But it is a requirment. So step lightly. I think mine is missing, but I cant remember.. No comment.
Mr Gadgets is offline
dukenrock
02-01-2007 09:29 PM
ofshore
2
07-31-2005 09:30 PM
electrical1
11
06-26-2005 11:58 PM
Formula29
12
04-09-2004 11:59 AM
RonS
08-19-2003 08:15 AM
