need advice more power from modified 525sc >
Old 11-09-2008 | 09:08 PM
Question need advice more power from modified 525sc
I need some advice on which way to go. I have a 454 similar to the 525sc setup, only with much better internals, cmi big tube headers, msd, etc., and a weiand 177 turning REALLY fast. It is making approximately 575-600hp.
I am looking at either a better supercharger (whipple) making more boost at cooler temp. or selling the motor and building a big cube N.A. motor
I am running this in a 271 formula and a xr drive. the boat currently runs in the low 70's. We are tweaking the bottom now for some more MPH. I know it isn't the best boat to go fast, but I love how it handles the rough water and its quality.
Any advice would be greatly appreciated.
Sam
formulaok is offline
Old 11-09-2008 | 09:09 PM
Got room for an 8-71? What is your static CR?
Back4More is offline
Old 11-09-2008 | 09:13 PM
yea, already added a scoop because of the intercooler
Old 11-09-2008 | 09:14 PM
static cr is 8.25:1
Old 11-09-2008 | 09:21 PM
If your using Alum. heads your good till 7.5psi without an innercooler.
Old 11-09-2008 | 09:57 PM
yes, they are aluminum heads and I do have a superchiller intercooler. With the same pully used on the stock 525sc setup, I was seeing 4.5# boost at WOT. When I went to the smaller pully, the boost rose to a little over 6, but not a huge increase in power. I know this is because at that higher blower speed, it starts making too much heat, so the 6#s or so isn't good boost.
Old 11-09-2008 | 10:29 PM
An 8-71 @ 7.5psi would be the best route.
Old 11-10-2008 | 01:15 AM
It definately needs a bigger supercharger to make more power. The 177 is at limits. I'm actaully surprised that your not seeing more boost with the smallest pulley though. It should make about 8# of boost with the smallest pulley.
Griff is offline
Old 11-10-2008 | 12:42 PM
how much power do you think I can get with the 8-71 and intercooler?
Old 11-10-2008 | 08:21 PM
You need to step up from the little guy to the big(ger) guy!
HaxbySpeed is offline
