oval port or rectangle port ? >
Old 11-11-2008 | 08:31 PM
Question oval port or rectangle port ?
I have a zz502 502 hp in my 22 Eliminator daytona. Can any body tell me witch is better oval or rectange port heads for top speed. thanks
plumb crazy is offline
Old 11-11-2008 | 09:45 PM
Loaded question. Do a search on the subject and you'll come accross lots of opinions.
Have fun!!
Kidnova is offline
Old 11-11-2008 | 09:50 PM
That depends on the specific heads you are talking about. If you're talking GM heads, then rect ports.
Griff is offline
Old 11-12-2008 | 06:58 AM
If I am not mistaken, the ZZ502 came with the Edelbrock Oval heads.
Like said above do a search and you will get plenty of opinions.
My question would be, how many RPM's do you want to spin it?
1BIGJIM is offline
Old 11-12-2008 | 07:00 AM
in the rpm range we usually turn max 5500-6000 the large ovals do very well #781's are about the best, more torque and mid....have run them with great sucess in race cars as well....my 482 blower motor I used them as well and worked great...sure you will get many opinions.....buy dyno charts I've seen always give the edge to those heads below 6k....Rob
ezstriper is offline
Old 11-12-2008 | 08:41 AM
PatriYacht's Avatar
If you're talking stock Chevy iron heads, 454 is a toss up between oval and rect. ports. 502 is better off with rect. ports. Mostly this is because of the small intake valves in the oval port heads. If you do some minor porting and change the valves to 2.25 intakes and 1.88 exhaust, the oval port will work well on a 502. But, by that time, your bargain heads are getting close to the price of Edelbrock aluminum or Dart iron heads .........
PatriYacht is offline
Old 11-12-2008 | 08:49 AM
PatriYacht's Avatar
For a 502 that turns 6000 rpms I would use Canfield 310 rect. port or Afr 305 rect. port. If you have lots of money, the cnc porting options will make a little more hp.
Old 11-14-2008 | 11:01 AM
Pat McPherson's Avatar
Yes, the ZZ502 has Aluminum Ovals with big valves.
I'd be happy to trade for a set of 120 hour HP500 Rec Ports I have sitting on the self...
Patrick
Pat McPherson is offline
Old 11-14-2008 | 07:57 PM
Yes Pat, you are correct. Here is the GMPP sheet on those heads. He really should change the intake along with those rect. heads. Make him a package deal.
http://www.crateenginedepot.com/stor...0-P163C66.aspx
ROTAX454 is offline
Old 11-14-2008 | 08:04 PM
Plum Crazy, If they look like these, then you do have the 3390 heads, made by Edlebrock for GMPP.
ROTAX454 is offline
