496HO 1/2" Oil System Plumbing Upgrade to 5/8"
The stock 496HO comes with 1/2" ID hoses and fittings. I want to add a bigger oil cooler and increase to 5/8" ID hoses and fittings (preferably retaining the current oil filter mounting on the custom Dana billet aluminum brackets that came with the Dana exhaust manifold kit and which uses retains the stock oil hose connection fittings).
The hoses are simple. It is the hose to engine and oil filter connection points that are the problem that I need help with. There are four connection points/fittings. The in and out oil hose connection points at the remote oil filter and the in and out oil hose connection points at the engine.
If anyone has done this up grade I would very much appreciate to learn how it was accomplished and where to get the necessary conversion fittings.
Thanks in advance for any help.
If you are running a bigger cooler, I would use a thermostat. Something like a Mocal High Flow-High Temp (sandwich type) about $100.00. Mount it to the remote filter pad(change this to a Ford type) If you are running the cooler in the stock location you can have Lenco make you a high cap. cooler to your specs. really reasonable. Oil Flow: Starts from offsett hole on engine blk filter pad............returns into lg center hole. Most say to have water flow and oil flow going opposite directions through cooler. Take Care-Dave
I already have a thermostatically controlled Hardin Marine oil cooler I am hoping someone on OSO has previously converted from the stock 1/2" oil line plumbing to a 5/8" (or 3/4" for that matter) and knows what engine interface fittings are needed and more specifically where to get them.
Bill
I turned my 502 (ZZ502/502) into a 557 and replaced the stock Merc lines with all -12. More HP = more heat, and the change was necessary. But as stevesxm said so elequently
you're probably spending $$ you don't need to spend......... JMHOI'll see if I can stick a pic of the -12s here
From: Where the water meets the oaks 'n Pines in the Sierra Nevada's of NorCal
check out below site-good info
http://forums.boatfreaks.org/showthread.php?t=11055
Thanks for the information on Henry's Engineering.
Gotta love stevesxms' subtle way of putting things LOL. But, I think he makes a good point. If your engine is stock I don't think you need the upgrade, unless maybe you run the bajeebers out of it. I'd say put an oil temp gauge on the engine and monitor oil temps. If your lines and or cooler are inadequate, the gauge will let you know.
I am running a very heavy deep v so at wot before I changed to -12, my oil temp was 40* higher. 4-my application, it was well worth the change over.
What engine are you running?
