Go Back  Offshoreonly.com > Offshoreonly Marketplace > New Products and Member Discounts
L I F T E R S !   L I F T E R S !    L I F T E R S ! >
Old 11-14-2008 | 03:46 PM
teaguecustommarine's Avatar
Offshoreonly Advertiser
Default L I F T E R S ! L I F T E R S ! L I F T E R S !
CRANE HYDRAULIC ROLLER LIFTERS: Mark IV Designed Chevrolet V-8, big block, all GM and 502 World big blocks. Vertical locking bar design to retrofit pre-hydraulic roller blocks. No machining required for installation.
For use with standard factory alignment bars on engines originally equipped with hydraulic roller lifters; and vertical locking bar drop-in lifters designed to retrofit engines ‘not factory equipped’ with hydraulic roller lifters. If there is any interference, the block can be ground to provide the necessary clearance. This should be checked prior to final engine assembly. Call TCM for special length pushrods used in retrofit applications.
TEAGUE CUSTOM MARINE SPECIAL- $571.68 ea.
*** NOW INSTOCK!! ***
Attached Thumbnails L I F T E R S !   L I F T E R S !    L I F T E R S !-lifters.jpg
teaguecustommarine is offline
Old 11-18-2011 | 05:47 PM
Check this out! Need Crane BBC Lifters? Check out the price from 2008, $571.97....
As of 11/2011 thru the new year..... CRANE 13652-16 @ $569.71set!!
All new model! Better Materials! Better Machining! Used in all Teague Custom Marine engines up to 1200 Horsepower!
http://teaguecustommarine.com/index....r-lifters.html
