Fuel hose to dash gauge???
Alec,
I dont know about a marine application, but in most car racing sanctioning bodies, that is a big NO-NO. Autometer has a fuel pressure gauge with an isolator that mounts at the fuel pump/engine end of the line and then a line with a inert fluid in it that runs to the panel area. Only thing is I am not sure if they make one with a line that is long enough to run in a boat.
Not sure if anyone makes an electric one or not. I personally would not want a pressurized fuel line running up to the dash panel, especially a plastic one. Does the CG allow any thing like this at all ??
Alec,,,,,,,,
wait untill JAN. - FEB. and i will have a new Gaffrig mech. fuelpress gauge with everything incl . for dashmount.
I will do the same thing in my raceboat ,because its the most accurate thing to have ,, mech. Fuel, Water and Oil press. !!
You can also call Mike or Marc from GAFFRIG Performance .
P-31
That's not crazy its just a question to get some right or wrong anwsers and get the most correct fuel pressur reading. Alot of boats have this set-up ,thats just stupid to say that your going to kill someone or yourself. Just think whats underneath your seat maybe a fuel tank ? What if the carb line starting leaking and hit's the coil ,and many other possible problems that can happen . I guess these are all Crazy things that can kill. I know they make electric sending units ,
But come on it's not cool to come off like that. Like I said it's just a simple question either good or bad. Peace
