BEST EXHAUST MANIFOLDS FOR STOCK 502 MPI's >
Old 11-19-2008 | 08:55 AM
Registered User
Default BEST EXHAUST MANIFOLDS FOR STOCK 502 MPI's
Who makes the best exhaust manifolds and risers for stock 502 gen 6 MPI's with Corsa captain's call? This is for a sportcruiser and fuel efficiency is more important than speed.
Moondance is offline
Old 11-19-2008 | 09:22 AM
kenvik01's Avatar
Registered User
I have Eddie Marine on my Challenger and really like them. I also saved over 200#'s off the back end. Mine bolted right up to the existing system. I paid a little over $3000 for 2 engines. Others (CMI, Stelling etc,) cost an arm and leg, but it depends on what you are looking to accomplish.
kenvik01 is offline
Old 11-19-2008 | 09:40 AM
The stock ones that came on the engine
1BIGJIM is offline
Old 11-19-2008 | 10:50 AM
Pat McPherson's Avatar
Stainless Marine, Imco, Revolution Marine, Dana, Gil, and ...
Lots of good choices.
I bought Stainless Marine.
Patrick
Pat McPherson is offline
Old 11-19-2008 | 10:58 AM
I had a pair of Eddie Marine on our 92 Fountain w/ 502's...
...worked well, easy to install
Carder
Carder is offline
Old 11-19-2008 | 11:19 AM
CPPerformance's Avatar
We carry a wide variety of exhaust systems from Gil to Imco to Hardin and then some. You can see most of them here--->http://www.cpperformance.com/product...t_systems.aspx
If you give me a call we can figure a system that fits your particular application the best and will give you the results you desire. Hope we can help,
Thanks,
Brian
CPPerformance is offline
Old 11-19-2008 | 11:59 AM
Exhaust will not change fuel efficiency to any noticeable degree. If fuel efficiency is what you're worried about, you've got the wrong hobby.
Griff is offline
Old 11-19-2008 | 12:41 PM
Registered User
Thanks everyone for your input, yes even you Big Jim but your statement is not correct.
Griff this is my life long hobby, I'm just asking for educated input, and I am simply stating what my directive is as opposed to horsepower.
Everyone else; Thanks again. Some one mentioned Imco Thumper series before but it doesn't mate to the Corsa. Imco has the performance series that would work if any one has experience with that let me know. Also I looked at the Stainless Kit and from what you guys wrote above that may be the right ones. CMI seems to only have header style. I will look at Eddie Marine, per your recommendations Carder, and kenvik01. Also I will look at Gil, Dana, and Revolution.
Thanks,
Moondance
Old 11-19-2008 | 06:03 PM
No matter what exhaust you put on, its gonna run within .2 mph of the same speed at the same rpm. It will be burning the same amount of fuel and won't be any more efficient.
The best thing you could do to make sure the boat is running at its most fuel efficient rpm/speed is to get fuel flow scans.
Griff is offline
Old 11-19-2008 | 06:20 PM
Registered User
CP Performance, nice web site, I saved as a "bookmark". I like the Stainless, and the Hardin kits. I want to look at Eddie Marine that the guys suggested.
