Go Back  Offshoreonly.com > Race Talk > OPA/The Jersey Boyz
Couple " Bat Boat " Small Blocks For Sale >
Old 11-24-2008 | 09:00 AM
2 Trick Rick's Avatar
Racer
Default Couple " Bat Boat " Small Blocks For Sale
http://www.offshoreonlyclassifieds.c...o26350-en.html
820HP each Fisher Engineering SB2 marine small blocks. They make 540 ftlbs of torque and are 250 lbs lighter than Big blocks.
2 Trick Rick is offline
Old 11-24-2008 | 09:02 AM
Wahoo ATV's Avatar
Racer
Yes, I have already spoken with Ray. These are some bad azz motors. Might be just a little too much for my Bravo.
Wahoo ATV is offline
Old 11-24-2008 | 11:23 AM
fantastixvoyage's Avatar
Cool power for the bat boat for sure - small cubes, high rpms. Assume he went with marine cams so can't say for sure but those SB2s typically make their power and torque #'s a bit higher in rpm. Throw a tower and some good internals in the bravo and you'll be fine.
So did you forget all about the beak boat or is that getting some upgrades too?
fantastixvoyage is offline
Old 11-24-2008 | 11:27 AM
FunHome's Avatar
Very Cool motors, What boat were they in???
FunHome is offline
Old 11-24-2008 | 11:38 AM
Wahoo ATV's Avatar
Racer
They were in the Unleashed Class 2 Cig
Old 11-24-2008 | 12:36 PM
glassdave's Avatar
Neno the mind boggler
ok . . . whats Ray got cook'in now
08 OPA High Points Champion
glassdave is offline
Old 11-24-2008 | 12:52 PM
Racer
Attached Thumbnails Couple " Bat Boat " Small Blocks For Sale-gas_turbine29_0009_300dpi.jpg
Old 11-24-2008 | 02:29 PM
glassdave's Avatar
knowing Ray . . . . anythings possible . . .
Old 11-24-2008 | 06:43 PM
TYPHOON's Avatar
How do you get 820 HP and 520 Ft Lbs out of a small block. Punched out to what Cubic inch? and what compression? What RPM? and how long will they last at WOT?
MD
TYPHOON is offline
Old 11-24-2008 | 07:04 PM
I'm curious how the horspower can be so high, 820 yet the touque only 520. A 383 small block crate engine comes with 460 lbs torque, so 520 does not seem too high.
Didn't Unleashed use to run 525's?
Fast Shafts is offline
