Merc Distributor Gear Removal >
Old 11-24-2008 | 06:23 PM
Default Merc Distributor Gear Removal
Is there an easy way to remove the split pin that holds the cam gear onto a Merc/GM distributor shaft? I've tried tapping it with a small hammer and nail on the pin but it doesn't want to move. I'm nervous about whacking it very hard and damaging the shaft, even with it mounted in a vice-
ctuck0659 is offline
Old 11-24-2008 | 06:38 PM
you need this you might be able to cut the point off the nail if you use a 3'' sinker nail
Rockfish71 is offline
Old 11-24-2008 | 07:15 PM
c,
Put the distributor on your bench with the gear sitting on a piece of wood. Get a hammer and the proper punch (not a nail) and it will come out.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
BillK is offline
Old 11-24-2008 | 07:34 PM
Ditto, just a roll pin, the nail has pointed head so wedges it tighter, you need a flat nosed drift of the correct size and will come right out. Could grind a flat on the end of the nail too maybe in pinch, but drift is the way to go if you can.
Originally Posted by BillK
c,
Bill Koustenis
Waldorf Md
happy hours is offline
Old 11-24-2008 | 07:38 PM
Default Thanks-
The pointed nail wedging the pin makes perfect sense. I've a couple/few punches, don't know why that didn't occur to me-
Thanks again-
Old 11-24-2008 | 10:12 PM
Strip Poker 388's Avatar
Rob
Talking
mine took a pretty good wack to get started
Attached Thumbnails Merc Distributor Gear Removal-whipples-3-15-05-001-large-.jpg
Strip Poker 388 is offline
Old 11-24-2008 | 10:13 PM
Even using the right size machine screw with a hammer will work.
Griff is offline
Old 11-28-2008 | 02:29 PM
Airpacker's Avatar
The point behing using a "drift" is the material the tool is made from transfers the force from the hammer more directly to the pin and dosen't absorb the force like a nail does. Nails are very soft steel. Drifts are hard tool steel. Big difference.
Airpacker is offline
kennyo
6
04-03-2008 08:01 AM
mark30h
4
09-14-2007 05:29 PM
fourplaydave69
6
01-04-2007 08:24 PM
Cmoney
6
04-27-2005 03:20 PM
