HELP engine builders Help
Old 11-26-2008 | 07:27 AM
Default HELP engine builders Help
Ok I can get a new engine at cost from the dealership but will I have problems using these in a marine application? My engine builder looksed at the specs for 30 sec and said we would need a new fly wheel and a short circulating pump and make sure it has a place to bolt on the mechaincal fuel pump.
FYI I am replacing my 330 hp 454. Seized the crank and have a sleeved cylinder.
Here are the links
http://www.gmperformanceparts.com/En...8774&engCat=bb
http://www.gmperformanceparts.com/En...8778&engCat=bb
drpete3 is offline
Old 11-26-2008 | 08:46 AM
Do a search on marine vs auto here on the board. There are alot of differences, cam, clearances, etc. You should find plenty of reading. I have a low hour Merc 7.4L I will let go fairly cheap. Let me know if you are interested
ThruHull is offline
Old 11-26-2008 | 09:28 AM
Need to replace the freezeplugs (from Steel to Brass).
All the gaskets need to be changed to marine standart.
Usualy if you built a marine engine the lash on everything is a little bit looser then on a car motor . But thats not a major thing.
Depends on how hard u run it .
A car engine is not made to run at 5000 RPM all the time . A boat does if u run it WOT .
DareDevil is offline
Old 11-26-2008 | 11:51 AM
I might be interested. Depends on dollars etc...Your along way from me though.
drpete3 is offline
Old 11-26-2008 | 12:03 PM
Yeah, not sure what shipping would cost. I tried to PM you but you have to be a paid member.
ThruHull is offline
Old 11-26-2008 | 01:45 PM
send me an email
[email protected]
drpete3 is offline
Old 11-26-2008 | 01:56 PM
Will do, I will try to get a couple fresh pics to send you as well.
ThruHull is offline
Old 12-01-2008 | 05:47 PM
http://www.1800runsnew.com/newbase-details-NLM.html#502
Rockfish71 is offline
Old 12-01-2008 | 08:56 PM
Email sent Pete!
ThruHull is offline
Old 12-10-2008 | 04:40 PM
bobbowobbo's Avatar
I'm just south of you and am needing some parts for my 7.4 overhauls in process, what would you want for the blowed up one?
Bobbo
bobbowobbo is offline
