Help with Powdercoating >
Old 11-26-2008 | 12:28 PM
Question Help with Powdercoating
I purchased a New set of Keith Eickert headers about 6 months ago and had them powdercoated as part of the purchase. Not long after I got them I noticed a few hairline spider cracks in the powder coat but nothing to bad, but it seems to be getting alot worse over the last couple months. What could be causing this?
ThruHull is offline
Old 11-26-2008 | 01:14 PM
Whipple Charged's Avatar
They may have not been prepped properly, and there was oil, gas, etc. on them from the castings, or the cold/hot cylce are shrinking/expanding too much for the PC.
Dustin
Whipple Charged is offline
Old 11-26-2008 | 01:28 PM
Thanks Dustin, I purchased them from CP, not sure who they use for their powdercoating. Not sure what to do from here
ThruHull is offline
Old 11-26-2008 | 01:42 PM
Give me a call...we could strip them and re-powder coat them for you. They will look brand new again.
Thanks,
Jim Browning Jr.
CORSA Performance
800.486.0999 ext 112
Corsa is offline
Old 11-26-2008 | 01:50 PM
Thanks,
Jim Browning Jr.
CORSA Performance
I may call CP if this is definately a prep problem and see if they will stand behind them at all. If not, I will definately give you a call.
Tosh
ThruHull is offline
Old 11-26-2008 | 02:01 PM
OK...Glad to help if I can.
Jim
Corsa is offline
Old 11-26-2008 | 05:05 PM
Default How do you strip powder coat?
I have some aluminum valve covers that are powder coated and I would like to strip it and just polish them. How do you get the powder coat off? I have been told to sandblast them, but then polishing them would be a lot more work. Any suggestions
Sledge Hammer is offline
Old 11-26-2008 | 06:39 PM
CPPerformance's Avatar
While I havent seen this yet I guess anything is possible. If you want to get the part in question back to us. Give me a call my name is Brian and I can issue a RGA# so that we can track the shipment and its processing. Once we examine and analyze the cause of the issue at hand we will work to correct it with you.
CPPerformance is offline
Old 11-26-2008 | 06:59 PM
"sand"blasting powder is a pain in the sack. It WEARS away rather than just coming off nicely like paint and/or rust.
A lot of people have the powder burnt off prior to having it abrasive blasted, works much better in most cases.
PJDiesel is offline
Old 11-26-2008 | 10:31 PM
Soak them in acetone. It should come off with a razor blade then.
Griff is offline
