Drain the gas??
Old 11-28-2008 | 01:27 PM
Default Drain the gas??
I haven't used my boat since June. It's been in dry storage at the marina since then. Since I didn't forsee not using it for six months, I didn't take any precautions as far as Stabil or any other fuel additive. Do I drain the tank or add some kind of fuel treatment additive before I run it again? I intend to service all of the fluids and filters, just wasn't sure about the fuel.
It's a stock '06 model 496Mag.
Thanks for any suggestions.
wantingmore is offline
Old 11-28-2008 | 01:50 PM
Just top it of,with some 90+ octane fuel after you changed the filters, you be fine.
Or put a little octane boost in it.
DareDevil is offline
Old 11-28-2008 | 02:12 PM
BAJA WILL's Avatar
Registered User
I agree, no need to drain tanks unless you think that the fuel has been compromised. Put some stabil in and fill it up with high test before you go out again.
WILL
BAJA WILL is offline
Old 11-28-2008 | 05:58 PM
TEAMBAJA's Avatar
If you havent used it since June when the fuel prices were still high, there is a good chance its already been siphoned out!
Jason and I were just down there. I guess we should have looked you up when we hit the water.
TEAMBAJA is offline
Old 11-28-2008 | 06:01 PM
90Velocity's Avatar
If it has ethanol I would drain it because it attracts moisture. If it doesn't have ethanol I would defintely save it. In upstate NY it is hard to find gas without it.
90Velocity is offline
Old 11-28-2008 | 08:14 PM
AKA "BAZOOKA JOE"
a little oc boost and top with 90 or plus you will be fine
bojoe2 is offline
Old 11-28-2008 | 09:11 PM
Make sure to put some Stabil in it NOW. I agree with the others. Add some 92-93 octane in the Spring and use it.
Griff is offline
Old 11-28-2008 | 09:27 PM
Get some sea foam and add it to the tank it will keep it stable and clean the carb/injectors in the spring.
The main issue is if its carbed the fuel in the carb will not have any stabilizer in it.
Since it is a much smaller tank it will varnish faster.
I have seen guys use stablil in construction equipment and have it turn to Jello in the carb. I think its garbage.
I am wondering why everyone says only 90+ octane? Whats the burn rate of the fuel got to do with stabilization?
Ethanol will attract moisture that is true but I am told it will also help bring that water trough the combustion chamber and burn it if it does get contaminated.
at least thats what I have been told by New england race fuels.
I would drain the carb if its not fuel injected or run the boat for a while on the hose to get some sea foam into it.
Just my $.02
30ctsutphen is offline
Old 11-28-2008 | 09:33 PM
Just my $.02
What is sea foam ??????????????
And higher octane fuel burns slower,therefor it will alow the moist to burn of.
Usually i think the 496 burns 89, so if old it will even lse more thats why u should put a little high grade in it.
Also i would not put anything else in my fuel tank exept for octane boost i hate stabil stuff.
If carbed and it dos not whant to start,emty fuel bowls and put a little fuel in the carb,then run it.
Befor u take any boat out u should run it on the hose anyways to check for leaks and overheating problems .
Thats my 2 cents.
Old 11-28-2008 | 11:22 PM
You should store the boat with the tank full, or very close to full. The higher the level, the less room you have for condensation. An almost empty tank has plenty of room for condensation to form. The water then goes to the bottom of the tank and is picked up first next spring. If you store it full, there is very little air space for condensation to form. You should also put some form of fuel stabalizer(Stabil or equivalent) and run the engine for a few minutes to get it through the whole fuel system and into the injectors and fuel rail.
Eddie.
Young Performance is offline
