502 cylinder heads torque specs >
Old 12-10-2008 | 07:19 AM
Default 502 cylinder heads torque specs
Hi,
I have a 98 gen6 502 , the manual claims the head bolts should be torqued to 92 lbs. Does that sound right. Thanks
alecsammy is offline
Old 12-10-2008 | 08:15 AM
Use the search. I know I saw it on there for stock and arp.
kennyo is offline
Old 12-10-2008 | 08:16 AM
offthefront's Avatar
89 on the Short bolts and 92 on the long ......use the Sequence in the book and work thru 3 rotations ...ie 30lbs ,59lbs .. then 89/92 ....coat the bolts with Perfect seal ... when you run the motor the first time get it good and hot ...shut it down ..let it cool and retorque .... As stated by kennyo depends on brand of bolts too ...they should be new ...ARP has specs on their website ..if you use their lube or reg oil ... different torque ... m
offthefront is offline
Old 12-10-2008 | 12:10 PM
Ditto.......it depends on the bolts and lube used.
Retorqing procedure depends on the head gaskets used.
Griff is offline
Smitty
3
05-04-2008 10:31 AM
collinmadden
2
06-26-2007 02:00 AM
HiPerf2000
3
05-10-2007 09:05 PM
kennyo
4
08-22-2006 01:07 PM
gene
1
09-27-2002 08:43 AM
