Can an engine from a boat with a speedmaster be installed in a boat w/ a bravo drive >
Old 03-12-2002 | 09:03 PM
powerguy's Avatar
Default Can an engine from a boat with a speedmaster be installed in a boat w/ a bravo drive
Looking at a used engine from a boat with a speedmaster III ( i believe) drive. Can that engine be installed in a boat with a bravo 1 drive without modification??
Thank for the help.
powerguy is offline
Old 03-12-2002 | 10:14 PM
Scott's Avatar
Charter Member #30
The speedmaster drive needs a transmission between the engine and drive. The Bravo doesn't. So unless I'm missing something here then the answer is yes you can use the motor.
I have Steps & Bubbles!
Scott is offline
Old 03-13-2002 | 12:21 AM
puder's Avatar
speel chekk this fokker!
i think you will need a bravo bellhousing for the engine instead of teh one for eth SM and tranny. You should be able to sell eth old SSM stuff though if it comes with the engine
Pardon me, while I whip this out!
puder is offline
Old 03-13-2002 | 06:17 AM
David's Avatar
You need to use a block mounted starter and a flywheel with the ring gear on the front, Bravo flywheel housing, and an engine coupler.
David is offline
Old 03-15-2002 | 01:33 PM
powerguy's Avatar
Thanks for the input. I am looking at buying a used HP500EFI that is in a boat with speedmaster #3 drives. Any idea on the cost to do the conversion to bravo setup??
powerguy is offline
Old 03-15-2002 | 03:33 PM
Goodfella's Avatar
GOT MERC?
Cool
Pricing on parts needed to do the coversion will run you approx
$1,384.00.
Which includes:
Engine Coupler
Flwheel
Flywheel Hsg
Starter
Bravo Shift Bracket
Goodfella is offline
Old 03-15-2002 | 07:35 PM
Mbam's Avatar
Offshoreonly Advertiser
Powerguy, you can do it for much less than that. You can do without the flywheel, just move the ring gear. There was a thread about this recently. If you want send me an email and I will work up the numbers for new parts, but I bet you can find most of what you need on this board. If you want you can look at some diagrams at 500 EFI
Mbam is offline
Old 03-15-2002 | 08:17 PM
Goodfella's Avatar
GOT MERC?
Cool
Hey Powerguy,
Yes Mbam is 100% right you can do the conversion cheaper if you run into a Mercuiser dealer willing to sell at just over cost.
Old 03-16-2002 | 05:49 AM
Biggus's Avatar
You should be able to find all the parts used, though I would go for a new coupler and starter.
Kurt
Biggus is offline
2 Trick Rick
OPA/The Jersey Boyz
23
03-08-2008 02:56 PM
LEOPAJM
12-13-2007 04:55 PM
Michael1
09-05-2007 04:38 AM
mats
11-29-2006 12:36 PM
diggerman
09-03-2006 09:22 PM
