Hey Guys newbie here. ? abou maintenance on a 88' Sr-1 311 >
Old 12-16-2008 | 02:08 PM
Default Hey Guys newbie here. ? abou maintenance on a 88' Sr-1 311
I am thinking of purchasing 1998 Formula Sr-1 311 for a guy locally.
It has twin 454 with low hours, built to Mercury marine race specs. The outdrives are perfomance TRS.
This is all new language to me as I am just getting into the boating scene. I had to change hobbies due to a bad injury which forced my to sell the motorcycles.
All though I know a little bit about engines I am not to fluent in the boating terms.
I was curious as to how much maintenance this boat will require. I know the term high Performance can be used pretty losely and he is trying to sell the boat, but I have had several Ducati bikes and they were considered High Maintenance and I did nothing really out of ordinary to them.
If you guys have any things I should look for or stay away from that would be awesome.
Thnaks,
Miles
movado750 is offline
Old 12-16-2008 | 02:32 PM
Hi Miles and welcome to the board. You will learn much from many here who have knowledge and gladly help others.
We need to know a little more about your proposed engines. What spec 454 are the base engines? Do you know what work was performed on the 454's to "Mercury racing specs". That phrase doesn't mean much without specifics. Those engines came in various stages of performance. The base engines were 330 hp with cast internals. There were also 420 hp versions that contained forged internals. These engines were very reliable power in their categories with the 420 hp engines being able to create much more power with simple modifications. TRS drives are now outdated, however, they were virtually bullet proof in that power range. Before purchasing the boat, you should have a qualified surveyor survey the boat and driveline. There are many names that can be recommended should you choose to perform a survey on the boat. If everything is in good condition, that is a very nice older boat to have. Where are you located? If you post some pictures of the boat, someone here on the board may have some useful information to share. Good luck.
Frank
thedonz is offline
movado750
12-18-2008 12:39 PM
hpy540
2
07-30-2007 12:44 PM
hpy540
5
05-15-2007 11:26 AM
BluWaterNC
12-30-2006 07:50 AM
