New dash for a Formula 382 >
Old 12-17-2008 | 05:57 PM
t500hps's Avatar
21 and 42 footers
Default New dash for a Formula 382
I'm having new panels made for my boat and they should be here in the next few days......still need to figure out placement of the oil/water temp and pressure gauges. The rest I feel are where they need to be. Any opinions?...panels are already cut so don't suggest moving holes!!!!
I'll be posting some before and after shots....as well as some along the way as this progresses. I can't believe the number of wires that are behind all these panels!!!!
File Type: pdf
t500hps is offline
Old 12-17-2008 | 06:13 PM
Depending on your sight lines with the steering wheel installed, I may switch the oil pressure gauges with the oil temp. I think the oil pressure gauges are probably more critical and have the possibility of changing quickly more than the temp. Other than possibly that, I wouldn't change a thing.
macjazzy is offline
Old 12-18-2008 | 04:09 PM
rjr
Somebody suggested rotating the gauges so that normal was up (or in the same direction) for them all. Seemed like a pretty good if somewhat strange looking arrangement.
rjr is offline
Old 12-18-2008 | 08:40 PM
Elite Marine's Avatar
Need gauges? I have good year end prices!!
[email protected]
Kirk
Elite Marine is offline
Old 12-18-2008 | 08:44 PM
t500hps's Avatar
21 and 42 footers
I'm re-using my existing gauges....not even re-using all of them.
Here is a before pic, should have the new panels tomorrow to start installing switches, bezels, and gauges.
t500hps is offline
Old 12-18-2008 | 08:54 PM
Real Nice Dash I Remeber How I Felt When My Dash Got New Monster Gauges And Air Brushed P.s Do You Know Anybody In Richmond Area Looking For A 38 Ft. Fountain Fever With Matchting Paint On A Ford Dualley? Bob
BAHAMA BOB is offline
Old 12-18-2008 | 10:48 PM
PhantomChaos's Avatar
I agree on the pressure guages.....but move the water presure up too. Pressure goes first....then the temp goes up.
PhantomChaos is offline
Old 12-19-2008 | 10:14 AM
My brother had his dash redone a little while ago, here is a link to it, it should have the company's name in there too. they did a very nice job.
http://www.donzi.net/forums/showthre...light=nisonger
zimm1978 is offline
Old 12-19-2008 | 10:32 AM
aTX427's Avatar
Just as an FYI, you can send your existing guages to Livorsi and they can change out the rins / faces at a very reasonable price.
aTX427 is offline
Old 12-19-2008 | 12:34 PM
t500hps's Avatar
21 and 42 footers
well, the panels showed up a little while ago....WOW!!!!!! I can't wait to get all this put back together!!!
t500hps is offline
