500EFI to 575SC Conversion
Off the Radar
I have two stock 500EFI's I am going to install some 575SC intakes. Anybody done this? Looking for suggestions of which way to go. My initial thought was to leave the compression stock, 8.75, keep the 500 roller cam, and just put 4lbs boost & let it go. Changing the pistons is not an option. The 500 cam looks like it would work OK but is there a better one to get? The 741 cam is real close to the old flat tappet B&M blower cam other than its on a 112. Wanting to be able to run on 87 if possible or 89. Any suggestions would be appreciated!
Linnie,
Did you pick up the blowers yesterday? Hope it worked out.
I noticed they had the smaller AZSM blower pulleys. You'll get more boost with those. May want to freshen the valvess and new head (Cometic) gaskets. Stock 575s have lower compression and need 91+ octane.
Good luck with the change over.
I had a set of 500 efi's in a 35' fountain and added the Vortech SC Kit and was VERY happy. You have to run 92 octane, which I think you would on any bolt on blower application. Without changing the pistons to lower compression you will have detonation issues with raising the compression after forced induction unless you use high octane.
You may also want to check if you add the 575 intake and blower to see if your injectors will work. You are going to definitely need an ECU reprogram no matter what you do but I just don't know if the stock injectors would work. I changed injectors cam and had ECU reprogrammed but had great results with no blower roll and had manners around the dock. Not to mention the 700+ hp with fuel injected reliability.
Off the Radar
Linnie,
Off the Radar
what props are you running
No. I pulled all 16 injectors and sent them off. I marked which motor and which cylinder they came from but did NOT tell the guy which pistons were tore up.......he called me and told me which 2 injectors failed and they matched the problem pistons/cylinders. Mark was positive the bad injectors were in the motor we never sent him...I just can't remember now which one we sent and which one stayed here.
The bad fuel issue your remembering is from after that rebuild, the boat had sat for nearly 2 months. The 2 month old fuel used while re-tuning the ECU actually showed some deterioration compared to the fresh we used as a test in a 6 gallon tank we rigged in the engine compartment.
Mark
