Go Back  Offshoreonly.com > Boating by Region > Mid Atlantic US
Winterizing cutoff line? >
Old 12-29-2008 | 08:14 AM
Default Winterizing cutoff line?
I understand that you don't need to winterize boats left in the water from Norfolk south. How about boats in racks, lifts and etc which are exposed. In Virginia and North Carolina do you winterize?Anyone have a cutoff line to go by?
Pat Ousborne is offline
Old 12-29-2008 | 09:24 AM
t500hps's Avatar
21 and 42 footers
I'm not far from Norfolk and I wouldn't leave a boat un-winterized.......about a week + ago we had 2 days that went from a low of 18, high of 38, low of 15, high of 31.......then it did get up in the 50's after that (and was upper 60's yesterday ). This is December and Jan/Feb are the coldest months. Do you consider those high/low temps acceptable to leave a boat un-winterized?
t500hps is offline
Old 12-29-2008 | 10:28 AM
That sounds too cold to me iof only December. Maybe in the carolinas would be a safe cutoff line.Although it probably won't do damage unless frozen solid which would need extended days at sub 32 degrees. I wouldn't chance it.?
Old 12-29-2008 | 04:10 PM
mwdill's Avatar
had a boat at a dealership in chesapeake, they had it over the winter and that year had 2 ice storms, when i got it back the block was busted in 4 spots!
mwdill is offline
Old 12-29-2008 | 06:26 PM
Maybe someone further south in VA or NC would have something to say? You winterize down there?
Old 12-29-2008 | 07:30 PM
You don't get much further south in Va than Chesapeake and you better winterize. Two or three days at or below 32 and it's busted. $8.00 a gal for antifreeze or $700.00 for a block or $1700.00 for manifolds. just my $0.02
formula 382 sr-1 is offline
Old 01-02-2009 | 03:14 PM
BAJA WILL's Avatar
Registered User
Agreed, who ever told you not to winterize in VA is NUTZ.
At our SML location we replace at least 6 motors a year from people not winterizing.
Whats really phubed up is people who bring in their boats now and the blocks are already busted, and they get mad at us. Any boat we winterize after basically Oct we have to look at very close.
WILL
BAJA WILL is offline
Old 01-03-2009 | 08:55 AM
Wow! I guess south carolina or georgia may not even be safe.So much for a year end trip to Va. to avoid winterization.Thanks!
Old 01-03-2009 | 09:20 AM
seafordguy's Avatar
You would be crazy not to spend a few minutes winterizing the boat. The antifreeze is also a good anticorrosive agent, as well as the obvious properties of keeping the block crack free....
My inlaws live in Holden Beach, N.C. - about the southernmost tip of N.C. and they see days that are cold enough to make me nervous.
seafordguy is offline
Old 01-04-2009 | 07:43 PM
I live in Central NC. Everyone winterizes here that I know. We have had many nights in the low twenties already and one day that never made it above freezing. I pay the marina $165.00 a year to winterize. Cheap insurance if you ask me.. Most of my friends just open all the drains in their blocks and drain the water out.. I have my engine run and filled with antifreeze because my Exhaust costs more than most of their motors do... Jeff Wurl
jwurl is offline
