Stnd. CMI tails Wet to Dry Conversion
Anyone ever converted a set of tails from wet to dry. It seems to me that a good welder (or CMI) could close up the 4 water exit holes, maybe leave one open, and install a bung in order to send the water out a thru hull on the transom. Surely someone has tried this... Thanks!
I talked to CMI about modifying them to dry, which would require cutting them up and extending them. Their concern was if one interal water dump was enought to keep the rubber boot cool. It seems like there would be a different material that would resist the heat better.
