Laying glass over glass???
Well I started my re-tabbing project this morning and all went well. I grinder the crap out of the area and cleaned it over and over with a vacuum and acetone.
I have layed a layer of glass 18oz (12 oz bi ax w/ 6 oz mat) and it is curing over night. I want to put a second layer on for added strenght. How do I prep the surface to lay new glass over the cured glass?
I am going over lap the cured piece by about 1/2 inch
Take some 60 grid and do it by hand ,just scuff it up a little,,,,,dont realy grind !
If it just sits overnight ,most likely u dont have to do anything just wipe down with aceton but not wet wet only a quick wipe for the dust.
The new resin will soften the old one since not fully cured.
you shouldn't need to grind it completely, just enough to knock off and burrs or ridges. If you used a standard laminating resin from USCompsites and no wax or finish type was used you should be ok.
best is to do as oldschool said, layup all at once if you can.
08 OPA High Points Champion
88teameliminator#7
Detailing, Painting, & Fiberglass
22
11-13-2007 03:14 PM
