Manifold spacers? >
Manifold spacers?
Manifold spacers?
Old 01-01-2009 | 11:18 PM
Default Manifold spacers?
I currently have standard deck 454's and available to me is a set of intake manifolds and blowers. The only problem is that they are for a tall deck. 10.200. Do they make spacers or could I have them milled? What else would I have to change? If I use spacers, would I have to change my distributor? Thanks
prostock85 is offline
Old 01-01-2009 | 11:48 PM
Wy,dont u just get intakes for standart block and sell the ones for the tall deck ?????
DareDevil is offline
Old 01-02-2009 | 12:00 PM
Mr Gadgets's Avatar
Charter Member #601
The tall deck manifolds are thicker on the head mounting flange than the short decks. So you need to remove material rather than put spacers in.
If you had tall deck blocks and short deck manifolds then spacers would solve your problem.
You could mill them or sell them and buy the correct ones like DD says. Might be a better route to go.
Hope this helps.
Dick
Mr Gadgets is offline
Old 01-02-2009 | 12:45 PM
Fenderjack's Avatar
Pirate of the Chesapeake
Default manifolds
Better to buy the short deck intakes. Save yourself a lot of grief.John
Fenderjack is offline
Old 01-03-2009 | 08:42 AM
I also agree with John.....buy the correct intake. If you need pricing and help with selection Please contact me. I am a WD for all. Thanks!
Dean Gellner
mrhorsepower1 is offline
38flatdeck
Swap Shop
5
06-13-2010 03:38 PM
Jassman
Active Thunder
20
10-01-2007 08:45 AM
Roger
Super Boat International
3
08-15-2007 01:19 PM
Jnewton
4
08-31-2005 12:17 PM
Jassman
01-08-2005 08:30 PM
