500 hp questions >
500 hp questions
500 hp questions
Old 01-05-2009 | 06:42 PM
Default 500 hp questions
How many hours is a 2000 500hp bottom end good for, oil, filter changed every 20 hrs with royal purple syn.
cam specs of a 2000 500 hp
cam specs of a 525
best alumniun heads for the money
thanks guys
rssteiny is offline
Old 01-06-2009 | 05:12 AM
I have 400HRS. on mine compression shows good. Everything runs fine. If your oil pressure is good. Do a leak down that really tells the story. A lot depends on how you treat it and how hard you run it. Royal purple helps I also use it in the drives and engine.
45SS is offline
Old 01-06-2009 | 06:19 AM
like said before, how it was treated/maintained, but if has been the way you say, 700-1000 hours should not be a problem on a good big block bottom end that never goes above 5600...now if you have had carb flooding issues, or ran high oil temps all bets are off...Rob
ezstriper is offline
Old 01-07-2009 | 08:11 AM
cam specs of a 525
thanks guys
Cam specs anyone??
rssteiny is offline
Old 01-07-2009 | 12:30 PM
specs for 525 EFI cam--Its a Crane cam.
298*/306* @ .004"
236*/244*
.610"/.632" Valve
114* LSA
HP500 carbed specs
284*/292* @ .004"
222*/230* @ .050"
.576"/.598" valve
110* LSA
Griff is offline
Old 01-08-2009 | 07:27 AM
Thanks griff
rssteiny is offline
Old 01-14-2009 | 02:13 PM
If the leak down test is less than 10% on all cylinders could i get away with just redoing my top end and wait a couple years and do a complete refresh. reason im asking is in my 32 active thunder my motors set up high and are real easy to pull heads , cams and so on, witout pulling motors.
thanks
rssteiny is offline
Old 01-14-2009 | 03:29 PM
you should be fine...how many hours now ? Rob
Old 01-14-2009 | 03:51 PM
430
rssteiny is offline
Old 01-15-2009 | 01:37 AM
If you're less than 10% then you could just do head gaskets. I don't think you will be able to get the cams out without pulling the engines or at least lifting them. Pulling the heads in the boat would suck.
Personally, I would just pull the engines even if you only do the top ends. It is much easier than messing around in the bilge and climbing and reaching. It will be less work in the long run.
I did a top end refresh on my 24 Outlaw with the engine in the boat. The entire back seat comes out and there is no bulkhead and it still sucked. Boat got dirty and its real hard on your back bending and twisting.
When I did the Pantera, I had the engine pulled. It was much easier with no sore back and no dirty boat.
Griff is offline
