McLeod bolsters in my 91' 292sr1?!?!? >
Old 01-05-2009 | 09:06 PM
Default McLeod bolsters in my 91' 292sr1?!?!?
Does anyone else have problems with the McLeod bolsters staying up? I called for the replacement cylinder and spring and she wanted $400 for it. If anyone else may have an alternative please advise.
gracias
threefour292 is offline
Old 01-06-2009 | 08:04 AM
I had a 92' 271 and had to have the cylinder rebuilt by the company that used to supply McCleod these cylinders. I think it was P. L. Porter and they are located in California. Looking at my old notes, I believe the phone number is 818-884-7260. These air assist cylinders were used in commerical jets. I believe it cost about $150.00 to get the cylinder rebuilt.
jkelly is offline
Old 01-06-2009 | 12:17 PM
Thanks jkelly.......i will try that out.
Old 01-13-2009 | 08:52 PM
I am switching mine out to power. Looks like it will cost about 100-150 per side. I am simply placing a linear actuator in place of the shock spring thingy and swapping out the button for a switch.
sabercatt is offline
Old 01-15-2009 | 10:25 AM
AIRFOIL292's Avatar
Mine were not holding and I check the cable.It turned out that the cable was not relaxed and still held the pin in to let the cylinder to leak down.Look in to that.My 2 cents.
AIRFOIL292 is offline
Old 03-03-2009 | 04:39 PM
NOMO's Avatar
gracias
At least she returned your calls! I have called and emailed Stephanie 4 times with no response yet (since the middle of January)!
NOMO is offline
Old 03-12-2009 | 04:30 PM
I need on for mine as well, Glencove at LOTO had one last year. Problem is, I think the whole seat has to come apart to replace it.
Tell me more about the swap to an actuator?
h2oboy is offline
Old 03-15-2009 | 08:52 PM
offthefront's Avatar
sometimes its the Button on the seat that is sticking and letting the cylinder leak down ....m
offthefront is offline
Old 03-16-2009 | 07:00 PM
my00b16si
any pic? we may have the parts you need in stock
Old 03-16-2009 | 07:05 PM
Strip Poker 388's Avatar
Rob
Shes back now,theve cut back there hours and laid off a bunch.try her again,.I got her all last week
Strip Poker 388 is offline
