Green plastic teardrops on Lugs? >
Old 01-08-2009 | 11:41 AM
outriggers's Avatar
Default Green plastic teardrops on Lugs?
Any of you big truck guys know what these are for? Nut tight indicator? I'm seeing them more often on different vehicles buses,garbage trucks ect. Thanks Doug
outriggers is offline
Old 01-08-2009 | 12:33 PM
always wondered what those did.
Perlmudder is offline
Old 01-08-2009 | 02:23 PM
Waste Management has them on their trucks...... I assummed they were indicators of lug tightness, as in if they moved out of alignment they would be coming loose.......
Jupiter Sunsation is offline
Old 01-08-2009 | 04:17 PM
If they fall of,,,the lug is gone . LOL
DareDevil is offline
Old 01-08-2009 | 11:50 PM
I'm not sure but think they prevent from turning counter clockwise if they are loose.
diggster69 is offline
Old 01-09-2009 | 09:57 AM
Sea-Dated's Avatar
http://answers.yahoo.com/question/?q...1190609AAwbvxl
Keep lugnuts from backing off.....
Sea-Dated is offline
Old 01-09-2009 | 10:10 AM
by giving a quick glance at the green pointers you can tell if a lug has come loose. They should all point in the same direction, unless one points the other way which will tell the driver to check that lug
KrystalTransport is offline
Old 01-09-2009 | 04:36 PM
what are they called, or where would you buy them?
RonS is offline
Old 01-09-2009 | 06:08 PM
http://www.wheel-check.com/
phragle is offline
Old 01-09-2009 | 06:49 PM
outriggers's Avatar
Thanks Prangle, That answers that,even most truck drivers don't know what they are. They might be good on a boat trailer. Not only do they indicate nut position, but if the temp goes above 120 degrees they blister, ie bearing or brake problem. Their site says a 1000 truck wheels come off a year. I can't imagine driving along and having a 11.00-20 come though my windshield. Doug
hpy540
08-01-2005 07:14 PM
fred
3
06-07-2004 08:16 AM
Frequency
05-19-2003 07:35 PM
PhantomChaos
06-04-2002 02:00 PM
