compression psi numbers >
Old 01-10-2009 | 04:50 PM
ak
Default compression psi numbers
Does anyone know what a good healthy compression test psi number would be on a warm big block chev with the throttle wide open?????????????This is on A 509ci,about 10:1 compression ratio,healthy cam and good heads.
ak is offline
Old 01-10-2009 | 05:16 PM
HotPursuit's Avatar
consistency between the 8 cylinders would be most important. Use a leak down gauge no questions on whats right. 100% is perfect anything below is your % loss.
HotPursuit is offline
Old 01-10-2009 | 05:48 PM
he's right. if you are locked into a compression test look for them to be 130 or 140 or so but remember, the more agressive the cam, the lower the cranking compression will be. whst s compression test will really tell you is if you haver dinged a valve or have some other meaningfull big sealing issue.
stevesxm is offline
Old 01-10-2009 | 05:53 PM
Its all going to depend on the camshaft. The larger the cam, the lower the cranking compression. As Keith said, you are looking for equality between the cylinders. That is more important than the actual number. I would think you should be somewhere around 175-180 psi. You need to be more concerned with the numbers being within 10 psi from highest to lowest.
Also as Keith said, a leakdown eliminates any questions. It will tell you not only what kind of shape it is in, but where the problem lies if you have one.
Eddie
Young Performance is offline
Old 01-10-2009 | 10:29 PM
10.2 compression/moderately aggressive cam 540CI NA dyno 640HP 145 lbs cylinder test + - 5% just for a refer. guide. j
I'CE is offline
Old 01-10-2009 | 10:59 PM
HotPursuit's Avatar
Eddie
Happy New Year Chalmation Brother!!!
Old 01-10-2009 | 11:06 PM
ak
Well i am doing great then,did a compression check,warm with throttle open got 189-192 psi across the board and leak down was 13% across the board,i used new matco testers for these tests,the leakdown gauge read 5-10% was the set mark,10-40% was low mark,40-70 was the moderate mark and 70-100% was high mark,so i guess she is pretty healthy.
ak is offline
Old 01-11-2009 | 01:08 AM
Pretty decent numbers. The leakdown is a little high, but its good that all cylinders are the same.
Griff is offline
fantastixvoyage
12
06-19-2007 06:09 AM
Andy
5
11-22-2004 05:48 AM
OldSchool
5
08-14-2004 09:35 PM
FlyFast
2
09-07-2003 10:07 AM
Intolerant1
17
08-09-2002 01:01 AM
