drive direction >
drive direction
drive direction
Old 01-16-2009 | 10:26 AM
Ken N's Avatar
Arrow drive direction
I was led to belive that a B1 drive (1999) can run in either direction. My drive has 200 hr. turning RH ed rotation. Do the gears like one direction for as long as they live?.
Ken N is offline
Old 01-16-2009 | 12:53 PM
I was told that in left hand rotation the gears push against the top cap.I ran mine with a left hand prop for years and then swapped to a right hand. I changed out my shifter cables and prop and still going!
kennyo is offline
Old 01-16-2009 | 01:19 PM
makes no diference which way you run a b1
rssteiny is offline
Old 01-16-2009 | 02:42 PM
SORRY, but yes it does.
Thats wy IMCO actually makes the top onthe left hand ones stronger.
I u run them on a twin just switch them from one year to the other,,but on a single u whant to run them RH because otherwise the top will wear out.
DareDevil is offline
Old 01-17-2009 | 02:04 AM
A Bravo 1 is designed to spin either way. Like was said, running it LH will put more pressure on the top cap. I have never heard of IMCO using different towers for LH drives.
Griff is offline
JJONES
Prop Talk
7
04-18-2006 07:13 PM
epeek
Fountain
22
01-22-2005 11:10 AM
flylevel
04-03-2003 11:55 AM
MIKEHTMSR24
3
03-23-2003 08:48 PM
HOTROD2
20
02-10-2003 07:13 PM
