Volvo / OMC ignition Rev limiter. >
Old 01-20-2009 | 05:15 PM
Default Volvo / OMC ignition Rev limiter.
My stock ignition on my 95 carbed 7.4 limits my RPMs to 4750. I think this is called the EES system? I tried to copy the “330 on Roids” build so my peak power should be closer to 5100rpms. I prefer to keep this ignition as it incorporates the knock sensor & will reduce timing if detonation is detected. Is there a way to disconnect the rev limiter on this system? I was told to disconnect the sensor on the flywheel but I think that is part of the timing advance system.
Itsallgood995 is offline
Old 01-21-2009 | 09:52 AM
I would seriously consider using a different ignition system.
the module for your system is discontinued. the system was not widely used. there is no way to reprogram the limiter that I know of. Use somethng else. what you use is up to you. there are plenty of people on this forum to give you their opinion on which one. good luck
JIMG is offline
Old 05-13-2009 | 03:26 PM
Hi,
i have a 98 VOLVO Penta 7.4 (454) engine. i want to reprogram my rev limiter or increase the limit, will be glad if you offer some suggestions
thanks in advance
maryokaan is offline
CPPerformance
New Products and Member Discounts
2
01-31-2008 06:08 PM
CPPerformance
0
04-13-2007 11:04 PM
CPPerformance
0
04-13-2007 05:40 PM
Corbs
6
05-14-2006 05:16 PM
nobudget
06-04-2002 11:21 PM
