marine carb clarification >
Old 01-22-2009 | 07:14 AM
Default marine carb clarification
Been looking for a carb. I was always under the impression a holly marine carb had the J tube. I can't tell you how many I've looked at and was told that's not true. What's the story??
CN24 is offline
Old 01-22-2009 | 11:53 AM
Holley marine carbs do have J tubes. Its a USCG safety requirement.
Griff is offline
Old 01-22-2009 | 12:55 PM
Default Marine Holley's
Throtlle plate shafts o-ringed so gas doesn't leak out
Clustergear is offline
Old 01-22-2009 | 05:26 PM
are you sure on that...I have pulled the shafts out of some marine holleys and there were no o-rings ? Rob
ezstriper is offline
Old 01-22-2009 | 05:44 PM
I don't know about o-rings, but all the Holley's I've pulled apart have had white teflon bushings in them. This is to keep them from sucking air. Thus helping to keep air to fuel ratios correct.
45SS is offline
Old 01-22-2009 | 09:32 PM
I have a marine Holly 800 dp just rebuilt for sale.
plumb crazy is offline
Old 01-22-2009 | 10:56 PM
Not sure about o ring thing, I haven't pulled throttle plates out of a marine holley in years. But I remember there is some thing different around throttle plate shafts so when it floods bad, gas doesn't leak from shafts out on to engine. It keeps the gas contained in carb and dumps into engine. I know I have a book or article somewhere about the difference, I will have to try and find it.
Old 01-23-2009 | 06:55 AM
excursion's Avatar
I bought my last Holly 850 carbs from A.E.D. and they know what they are doing and the only difference is the J tubes are turn around to face the intake of the carb.
excursion is offline
Old 01-23-2009 | 12:54 PM
So basically "no j tube", "no marine carb".
CN24 is offline
Old 01-23-2009 | 05:56 PM
If J tube is only difference then change them and you would be all set???
stormbauer is offline
