575 Sci timming question >
Old 01-24-2009 | 02:09 PM
Default 575 Sci timming question
someone was telling me in order to set the timming on the Merc 575 Sci, you have to bypass or do something like that to the computer?
lowblue320 is offline
Old 01-24-2009 | 06:18 PM
On the data link connector, jumper pins A and B together,
or ground pin B. Pin B should be a WHT/BLK wire, pin A is
a BLK wire (obviously pin A is ground).
The data link connector is the connector at the rear of the
engine for the diagnostics.
Pesky Varmint
Pesky Varmint is offline
Old 01-24-2009 | 06:38 PM
Pesky Varmint
Thanks, let me ask you another questions what will happen if I set the timming with out jumping the computer?
Old 01-24-2009 | 06:41 PM
jeff1000man is offline
Old 01-25-2009 | 06:56 AM
Linster's Avatar
Off the Radar
Merc makes a timing tool that is very cheap, that jumps the two pins. It comes with instructions. Basic timing is set at 8, at 1800 rpm.
Linster is offline
Old 01-25-2009 | 08:48 AM
If you try to set the timing without the jumper, the timing
won't be sitting still at any particular setting, it will be jumping
all around. The timing continually varies because it is partly
how they control the idle speed.
At least thats what the guys at Arizona Speed and Marine
told me.
Pesky Varmint
lowblue320
12-13-2007 10:30 AM
lowblue320
1
12-10-2007 07:57 PM
dennis r
1
07-19-2007 08:34 PM
jharran
3
05-21-2007 09:15 AM
Quiet Storm
8
02-01-2003 11:02 PM
