24 Pantera trl. question??
I have a 24 pantera I/O and need a trailer, found a good deal locally it is an ace alum. single axle. Axle rated a 6k and trl. rated at 5300lbs but owner says 23 max. lenght.. Would this work?? Hate to buy and make a mistake. Thanks
too small, bh makes an excellent point...
i once towed a 22 scarab a short distance on a single axle...one of my "not so bright " moments, it just wasn't well balanced. my 24 condor sat on the smallest tandem made, and it was a much better fit than the biggest single. I currently have an ace trailer ($3800ish new&delivered set up for the sutphen)...great stuff, but you should really go tandem
c
c
I bent an axle once (tandem trailer) on my 24 python. Probobly would have sent the boat sailing if it was a single axle. It may hold it, but if you hit a good enough bump or dip on the highway as I did it could really be a nightmare.
