anybody know about seacast? >
Old 01-25-2009 | 07:48 PM
Question anybody know about seacast?
possible transom repair!
stevekyp is offline
Old 01-25-2009 | 08:43 PM
I know your boat is an ob config but the ib guys here don't like it. From what I have read in previous threads, it lacks the strength of ply & glass. The small ob boats of upto 20' seem to be ok but bigger heavier hulls like ours should definitely go the traditional way. Try looking up Coosa Composites as an alternative & there is also a guy here with a 38KV who went the whole glass way.
Good luck
jez350 is offline
Old 01-25-2009 | 11:19 PM
just do it the right way. you have it easy compared to twin io's, check the stringers while your at it. it is an 80's wellcraft. it's not difficult to put it back together much better/stronger than when it left the factory either
phragle is offline
Old 01-25-2009 | 11:36 PM
glassdave's Avatar
Neno the mind boggler
Good luck
yep, stick with glass and ply. Coosa is not good for transoms especially an OB boat..
08 OPA High Points Champion
glassdave is offline
Old 01-25-2009 | 11:52 PM
Thumbs up
thanks guys
talk to you soon again!
stevekyp is offline
Old 01-26-2009 | 05:12 PM
rchevelle71's Avatar
Hey Dave,
I am going to be doing this project soon also, what kind of ply would you use??
rchevelle71 is offline
Old 01-26-2009 | 05:42 PM
home depo sells 11ply plywood at $40.00 for 3quarter sheets.
my transom is 2and3 quarters thick
with west system.... will the wood still rot after a long time?
stevekyp is offline
Old 01-26-2009 | 05:54 PM
gona do the transom myself in spring time!
the sea cast question was for my brother inlaws boat.
i am an ex mechanic now doing construction here in mass.
let me tell you guys something.
i made plenty of header beams for houses,like an lvl laminated venner lumber,and this plywood is indistructible!!!
i can only imagine when being glassed!!!!
stevekyp is offline
Old 01-26-2009 | 05:58 PM
these sheets of ply wood are heavy but very strong!!!
stevekyp is offline
Old 01-27-2009 | 10:34 AM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
I use composites or wood for rebuilds/builds.
The seacast would concern me if used on large area. I would think it like using concrete for a large structural item without using rebar.. Just my 2 cents.. Jamie
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
