AT gurus, question on PR lay up and performance >
Old 01-27-2009 | 01:27 PM
BAJA WILL's Avatar
Registered User
Default AT gurus, question on PR lay up and performance
Seen some recent adds on a 37 AT saying its the Poker Run lay up?? Does AT offer such a upgrade and if so ball park $$ what it adds to cost and performance, say with 525efi's
Also what is a 37 AT hitting with 700's and nxt's
WILL
BAJA WILL is offline
Old 01-27-2009 | 01:37 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
WILL
Poker Run "layup"/build generally refers to a boat without a cabin liner; as such the cabin is built in custom components. Such allows for a MORE custom/plush cabin than a cabin liner OR a more streamlined cabin for just a go-fast boat. $$ all depends on what you want in the cabin-carbon fiber, Corian, laminates, brushed aluminum, leather, Pleather, vinyl, Lonseal, carpet, etc. etc.
There are a few things that can change with the actual layup schedule depending on the desired use of the boat by the owner. That's why its custom and there are no set figures. The lighter cabin can pick up a couple miles per hour, but again, each and every boat is different. If you go with a PR layup/cabin, but add a diesel generator, you have just alleviated the weight savings.
The 37AT with 700NXTs was PRA Magazine tested at 105 and change; with a cabin liner, plush cabin, AC, intercoms, stereo & subs, and all the bells.
Sydwayz is offline
Old 01-27-2009 | 01:54 PM
BAJA WILL's Avatar
Registered User
Cool, thanks Brian.
Good #'s on the 700's, Has Pat tried #6 lowers bolted to the NXT?? props are more expensice but will pick up a few more mph.
WILL
yahoo
Insurance and Finance
1
08-26-2006 03:07 PM
hpy540
15
12-26-2005 11:04 AM
formula31
19
04-02-2003 01:18 PM
formula31
4
02-19-2003 04:45 PM
