Would this carfax report scare you? >
Old 01-29-2009 | 09:59 AM
Default Would this carfax report scare you?
This is an older womans car. 1998 Lincoln Mark VIII Supposedly maintained under contract by the dealer. 1st oil change at 13K! Tranny replaced,3 times for brake work! I had a 96 and put over 70K on it and didn't have to do anything except a waterpump and alternator! No brakework either!
Date: Mileage: Source: Comments:
04/09/1998 NICB Vehicle manufactured
and shipped to original dealer
06/29/1998 Lynnhaven Lincoln Mercury
Virginia Beach, VA
757-340-0800
www.greenbrierlynnhaven.com
ww.greenbrierlynnha
ven.com Vehicle sold
06/29/1998 200 Virginia
Motor Vehicle Dept.
Norfolk, VA Vehicle purchase reported
Odometer reading reported
07/22/1998 Virginia
Motor Vehicle Dept.
Virginia Beach, VA Title or registration issued
First owner reported
Registered as
corporate vehicle
05/22/2001 13,640 Lynnhaven Lincoln Mercury
Virginia Beach, VA
757-340-0800
ww.greenbrierlynnha
ven.com Vehicle serviced
Oil and filter changed chassis lubricated
Manufacturer's recommended maintenance performed
State inspection completed
05/30/2001 Virginia
Motor Vehicle Dept.
10/31/2001 18,789 Lynnhaven Lincoln Mercury
Virginia Beach, VA
757-340-0800
ww.greenbrierlynnha
Tires rotated
Battery replaced
Battery/charging system checked
06/22/2002 24,165 Lynnhaven Lincoln Mercury
Virginia Beach, VA
757-340-0800
ww.greenbrierlynnha
Rear brakes replaced
Fuel filter replaced
07/30/2002 25,013 Lynnhaven Lincoln Mercury
Virginia Beach, VA
757-340-0800
ww.greenbrierlynnha
09/12/2002 Virginia
Motor Vehicle Dept.
05/09/2003 32,162 Lynnhaven Lincoln Mercury
Virginia Beach, VA
757-340-0800
ww.greenbrierlynnha
07/02/2003 34,060 Lynnhaven Lincoln Mercury
Virginia Beach, VA
757-340-0800
ww.greenbrierlynnha
08/14/2003 35,090 Lynnhaven Lincoln Mercury
Virginia Beach, VA
757-340-0800
ww.greenbrierlynnha
10/08/2003 36,535 Lynnhaven Lincoln Mercury
Virginia Beach, VA
757-340-0800
ww.greenbrierlynnha
Maintenance inspection completed
Wheel speed sensor replaced
11/10/2003 Virginia
Motor Vehicle Dept.
Registration updated when owner moved
the vehicle to a new location
11/24/2003 37,450 Lynnhaven Lincoln Mercury
Virginia Beach, VA
757-340-0800
ww.greenbrierlynnha
Front brake pads replaced and rotors resurfaced
02/04/2004 39,007 Lynnhaven Lincoln Mercury
Virginia Beach, VA
757-340-0800
ww.greenbrierlynnha
Engine/powertrain computer/module checked
Instrument cluster checked
Fuel system checked
Ignition system checked
Camshaft position sensor replaced
Body computer/module checked
Crankshaft position sensor replaced
Fuel pressure checked
04/27/2004 40,389 Lynnhaven Lincoln Mercury
Virginia Beach, VA
757-340-0800
ww.greenbrierlynnha
Brakes checked
Tire condition and pressure checked
07/21/2004 42,554 Lynnhaven Lincoln Mercury
Virginia Beach, VA
757-340-0800
ww.greenbrierlynnha
Front brake rotors resurfaced/turned
Parts ordered
Transmission replaced
Seatbelt assembly replaced
Automatic transmission cooler flushed
Transmission checked
Transmission overhauled
Transmission overhauled/replaced
Automatic transmission cooler replaced
09/13/2004 Virginia
Motor Vehicle Dept.
Norfolk, VA Title or registration issued
10/14/2004 44,510 Lynnhaven Lincoln Mercury
Virginia Beach, VA
757-340-0800
ww.greenbrierlynnha
Brakes checked
Tire repaired
01/14/2005 46,608 Lynnhaven Lincoln Mercury
Virginia Beach, VA
757-340-0800
ww.greenbrierlynnha
02/24/2005 47,321 Lynnhaven Lincoln Mercury
Virginia Beach, VA
757-340-0800
ww.greenbrierlynnha
Power steering fluid flushed/changed
Engine compression checked
Brake fluid flushed/changed
Ignition coil(s) replaced
A/C system serviced
A/C and heating control assembly checked
Blend/diverter door actuator replaced
06/16/2005 50,233 Lynnhaven Lincoln Mercury
Virginia Beach, VA
757-340-0800
ww.greenbrierlynnha
Brakes checked
A/C cycling/pressure switch replaced
A/C system serviced
Parts ordered
06/27/2005 50,487 Service Plan Co.
Virginia Beach, VA Service contract issued
07/25/2005 50,923 Lynnhaven Lincoln Mercury
Virginia Beach, VA
757-340-0800
ww.greenbrierlynnha
Exterior light bulbs replaced
Service contract claim
Electrical system serviced
08/22/2005 Virginia
Motor Vehicle Dept.
09/26/2005 52,331 Lynnhaven Lincoln Mercury
Virginia Beach, VA
757-340-0800
ww.greenbrierlynnha
Idle control valve/motor replaced
Battery serviced
Battery replaced
Induction system serviced
Four wheel alignment performed
Tires rotated
Brakes checked
Fuel system serviced
Suspension serviced
11/14/2005 53,010 Lynnhaven Lincoln Mercury
Virginia Beach, VA
757-340-0800
ww.greenbrierlynnha
A/C serviced
06/20/2006 56,501 Lynnhaven Lincoln Mercury
Virginia Beach, VA
757-340-0800
ww.greenbrierlynnha
Front wiper blades/refills replaced
Brakes checked
08/30/2006 57,173 Lynnhaven Lincoln Mercury
Virginia Beach, VA
757-340-0800
ww.greenbrierlynnha
Brakes checked
09/07/2006 Virginia
Motor Vehicle Dept.
Norfolk, VA Registration issued or renewed
10/13/2006 58,318 Lynnhaven Lincoln Mercury
Virginia Beach, VA
757-340-0800
ww.greenbrierlynnha
Two tires mounted and balanced
Tires rotated
11/14/2006 59,393 Lynnhaven Lincoln Mercury
Virginia Beach, VA
757-340-0800
ww.greenbrierlynnha
Brakes checked
Serpentine belt replaced
02/16/2007 62,036 Lynnhaven Lincoln Mercury
Virginia Beach, VA
757-340-0800
ww.greenbrierlynnha
Brakes checked
A/C serviced
08/03/2007 64,045 Lynnhaven Lincoln Mercury
Virginia Beach, VA
757-340-0800
ww.greenbrierlynnha
Brakes checked
Safety inspection performed
09/07/2007 64,195 Lynnhaven Lincoln Mercury
Virginia Beach, VA
757-340-0800
ww.greenbrierlynnha
09/17/2007 Virginia
Motor Vehicle Dept.
06/27/2008 65,449 Lynnhaven Lincoln Mercury
Virginia Beach, VA
757-340-0800
ww.greenbrierlynnha
Ignition key reprogrammed
Cruise control switch replaced
10/10/2008 65,858 Lynnhaven Lincoln Mercury
Virginia Beach, VA
757-340-0800
ww.greenbrierlynnha
11/07/2008 Virginia
Motor Vehicle Dept.
pachanga is offline
Old 01-29-2009 | 10:43 AM
NO,,,,look how many costumers it made happy !!!
DareDevil is offline
Old 01-29-2009 | 11:28 AM
damn
Perlmudder is offline
Old 01-29-2009 | 01:38 PM
c_deezy's Avatar
Only drove 6-7K miles a year. Everybody knows shorter, in-town miles are a lot harder on a car than highway miles. My 10 year old car with 277K is a testimony to that. And based on the rest of the history, I'd say for certain she had at least two oil changes prior to the first documented one at 13K, probably one shortly after buying the car and another around 6K miles.
c_deezy is offline
Old 01-29-2009 | 01:58 PM
jayhawk261's Avatar
Just because the first documented oil change on the car fax is at 13k, doesn't mean it hasn't had the oil changed. Obvoiously if it is self changed or done at an independent shop/jiffy lube type place it won't be on the car fax. As far as the other things go, the brakes could be due to a 2 footed driver always holding a foot on the brake pedal. It seems like a lot of older people do that. And with the transmission, sometimes they just are screwed up and need replaced. It could have been a bad one from the factory and had an unusually short life.
jayhawk261 is offline
Old 01-29-2009 | 02:56 PM
The part that scares me about the oil changes is this car was bought(I think) under a lease with all service included. The daughter is selling the car. Do dealers sometimes forget to record all services done to a car. The daughter was adiment about the dealer performing all the maintainance. She also called me a liar when I presented her with the carfax details. YIKES
If I was looking at a car driven by a younger person I would automatically assume the car had the sh*t run out of it. I guess the back brakes going so quick could be from leaving the parking brake on...but the driver would have to be blind and deaf. The other reason could be caused by the traction control system which is peformed by the brakes.
Looks like jack rabbit starts and stops to me! LOL...My Great Grandmother used to scare the sh*t outta everybody(according to the family tales). Salesman talked her into a 65 or 66 T-bird with the twin 4BBL Bigblock. She didn't let any grass grow under her feet!
pachanga is offline
Old 01-29-2009 | 03:10 PM
c_deezy's Avatar
Could be that routine maintenance didn't use to get logged in carfax, hard to say. Back brakes needing done could be from a bad design, I had a early 90's pontiac that I had to do the rear brakes on all the time because the pins would sieze and the caliper couldn't slide. Carfax is only one part of it, carefully looking the car over should tell another part.
c_deezy is offline
Old 01-29-2009 | 09:48 PM
I have seen some cars that were painted at Ray Charles body shop and show a clean car fax. Alot of shops dont report to carfax. Car fax is just a guide at best. Look at the car and make a judgement. How much does she want for it?
Carguy08 is offline
Old 01-29-2009 | 10:25 PM
I probably should buy it. Kelly Bluebook trade in is 3K in Excellent. (retail 57) She is in the high 4's. Nice ones are bringing in the 4's, but many are well under 3. Kindda like...I guess I would pay more for 1 with lower milage. On the fence about an LSC because of the headlight issue. I like the LSC better but the headlights are an issue now.(this is not an LSC) Also didn't know it was a northern car until I did a carfax. Car is forsale in the SE. The air suspension is an issue with all of them and winter salt does take it's toll.
pachanga is offline
Old 01-30-2009 | 08:14 AM
BillR's Avatar
OSO Moderator
Va Beach area is not Northern.
Haven't seen salt on the road here for 3 - 4 years.
It looks like it was well maintained
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
