My boat weighs....... >
Old 01-29-2009 | 04:03 PM
Default My boat weighs.......
I took my boat down to a scale yesterday and weighed my boat. It's a 29 Fever with a single 500 EFI and ~100 gallons of gas and a tri-axle trailer. With my boat and all the gear (anchor, lifejackets, trailer, etc..) it weighs 8580 lbs. I don't know how much help this will be for anybody, but if you were curious to what the 29 weighed, there it is.
Racerngr1 is offline
Old 01-29-2009 | 07:42 PM
5500 lb for the boat
~2000 lb for the trailer
600 lb for the fuel
~ 8300 lb total, it adds up quick! "Yeah, I'm sure your Ford SportTrac could pull it"
bob_t is offline
Old 01-29-2009 | 10:28 PM
Hell 08 diesel tows that like crap, but that's a whole other story!
Old 01-31-2009 | 11:39 AM
BAJA WILL's Avatar
Registered User
Nice, I tell people all day long, its more weight than they think. Imagine a 38TE with 420 gallons of fuel, I have seen 4X4 Dually drugg down the ramp until the boat floats.
BAJA WILL is offline
Old 01-31-2009 | 05:02 PM
.I had a fun trip down the ramp in Florida a few years ago with my 42 and a load of fuel!!!! Dually 3500 Dodge. Lots of fun thoughts going through your head when it's happening.
fountainracing65 is offline
Old 02-02-2009 | 01:59 AM
How do you get the boat back out of the water? Just the difference in weight of the gas you burnt?
Old 02-02-2009 | 08:42 AM
mjc
I had the dragging down the ramp problem with my 29' and a 87 daully.. I blame it on the bridgestone tires I have now they just get no traction. Now I lower the air pressure down to about 25 psi and have no problem. I only tow about 4 mile to the ramp so any farther than that I fill them back up.
mjc is offline
Old 02-02-2009 | 09:29 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I've been preaching about how heavy the total towed package becomes for YEARS, but no one listens unless they run their own setup across a scale.
8250 lbs. for my old Sonic 26/500EFI/POS Aluminum trailer/100 gallons/gear.
Sydwayz is offline
Old 02-02-2009 | 10:33 AM
BAJA WILL's Avatar
Registered User
AHH good question, coming out is a world diff, coming out 4 wheel drive low, and don't stop until your out of the water and level. The momentum allows you to come out much easier than you would think.
WILL
Old 02-02-2009 | 12:41 PM
I could not believe what mine weighed, did the same thing last summer. 312 fastech on my trailer weighed 11,400 lbs. I have an F-250 4x4 and find when I back down a slick ramp, I leave it in drive and let the boat pull me down and just step on the gas a little then all four tires can grab to help slow the momentum.
dave krehbiel is offline
