Fuel level gauge freaking out >
Old 01-29-2009 | 11:20 PM
Question Fuel level gauge freaking out
Now that I'v learned all about the Mercathode, I have another thing that has been bugging me that maybe someone can help me with. With the boat at rest, the fuel level gauge reads fine. Under way the needle freaks out and starts jumping all over the range. You think gauge, sender, loose wire or?
Thanks for any help.
blefever is offline
Old 01-30-2009 | 03:23 AM
Cheap float sender !!!!!
Use an electric sender ,they dont have a float !!!
DareDevil is offline
Old 01-30-2009 | 07:24 AM
Elite Marine's Avatar
The only true solution to erratic or inaccuracte gauges is:
http://www.livorsi.com/catalog/senders.htm#fuel_level
We need to know the depth of your tank to quote you properly.
Let us know if we can help.
Elite Marine
Elite Marine is offline
Old 01-30-2009 | 08:18 AM
float sender.
mr.boat is offline
Old 01-30-2009 | 11:08 AM
When you say underway, is that at idle?
Assuming you me underway as on plane then... Typically, the standard issue sender provides poor damping to begin with. If you know that at one time your fuel gauge did not do this, then you may want to try replacing the sending unit.
Personally, I would just live with it, since it's probably not real accurate anyway, espcially if you have a irregular shape tank.
Zackman is offline
Old 01-30-2009 | 11:34 AM
c_deezy's Avatar
Another thing is to make sure you are getting good signal to/from your gauge and to/from your sender. I had a problem this year with a finicky gauge after I replaced some battery cables and finally found out during winterization the sender wire was rubbing on the water pulley
It was funny too because I was ****ting on my last run hoping I would run as much gas out of the thing without running out of gas!
c_deezy is offline
Old 01-30-2009 | 12:30 PM
Check the ground wire connections at the sender.
Griff is offline
Old 01-30-2009 | 09:05 PM
trips2win's Avatar
I have the same thing and replaced the gauge and still happens whats left is wire and sender
trips2win is offline
Old 02-03-2009 | 02:35 PM
Thanks to everyone for the help. Sounds like I need to check wires and then the sender, and most likely spend more money. It's a boat, but as I like to say "Fun is Cheap at any Price" and boats are a lot of fun.
blefever is offline
Steve_H
4
02-03-2007 11:58 PM
Biggus
8
06-02-2004 06:42 AM
CHAOS REIGNS
Pantera
1
04-21-2004 09:27 PM
H2Xmark
7
08-04-2003 10:48 AM
JROMY
2
07-23-2003 07:29 AM
