don't want to put Hatch Scoop >
Old 01-30-2009 | 12:07 AM
Default don't want to put Hatch Scoop
Mike wrote:
Hello group, i'm putting a tall motor/blowers in my 33 Outlaw and the only way it fit's is to put the scoops in. With the groups help, i got to see some pictures of the scoop on a Baja, but i don't like it at all. Has anyone done a raise to the hatch, to increase the hight, so one does not need a scope, to make it look like a sleeper/factory look? Any Pictures?
empire0007 is offline
Old 01-30-2009 | 07:35 AM
glassdave's Avatar
Neno the mind boggler
what are the dimensions of the opening? I may have some options
08 OPA High Points Champion
glassdave is offline
Old 01-30-2009 | 09:18 AM
Sean's Avatar
how much room do you need...would these help?
http://www.offshoreonly.com/forums/c...sombreros.html
Sean is offline
Old 01-30-2009 | 10:12 AM
Mike wrote:
I am about 4 inches short. I don't have the exact dimentions, but they are for a bouble carbs on each side. I would need to raise it about 4". I would hate to use the scoop. To raise the sides 4 inches will look very high.
i had a 32 baja outlaw that i put blower motors in.i cut holes in the hatch,made boxes from .125 aluminum,mounted them in the holes and made a new pad for the hatch out of high density foam,i used 6 in thick foam instead of the origional 2 in foam,then called baja,they sent me new material to put over the foam,when it wad done,it looked like it came from baja that way.
mike tkach is offline
Old 01-30-2009 | 03:42 PM
Default Hidden the Goods
Maybe this will Help 27' Baja=540 Blowner & chillier I used 4" stainless Steel Channel.
Attached Thumbnails don't want to put Hatch Scoop-p1300001.jpg   don't want to put Hatch Scoop-p1300002.jpg   don't want to put Hatch Scoop-p1300004.jpg
rleeds5761 is offline
Old 01-30-2009 | 05:32 PM
Brent Medley's Avatar
Gary Taylor makes an awesome low profile wide scoop. These things are huge......I installed a pair on my boat..........I too thought having a custom raised hatch made before I found these.....
Brent Medley is offline
Old 01-30-2009 | 05:39 PM
Any pictures?
ciaoderhead is offline
Old 01-30-2009 | 11:13 PM
Some people put an insert on the underneath side of the hatch to give more clearance without altering the pad. Maybe that combined with some low profile flame arrestors will work...
ToMorrow44 is offline
Old 01-30-2009 | 11:40 PM
This is a shot of a 33 with 575's I can't see why even 8-71's wouldn't fit in there...are you running innercoolers? Rasied carb flanges? What is the distance from the crank centers to the top of the flame arresters
Back4More is offline
