Core Material >
Core Material
Core Material
Old 03-16-2002 | 10:40 AM
Kent Perroux
Default Core Material
Does anyone know what composite material Apache is using in thier transom and stringers now? Eric (with Apache) was showing me some pretty stong black material they were using now last time I was there. I forgot the name of it. It is being used in place of plywood and is very strong.
I am redoing my transom and beefing up my stringers in the engine bay and want to use this material.
Kent
Old 03-16-2002 | 04:35 PM
Kent:
I can't say for sure what core material apache uses. It probably is balsa core.
Baltek Corp. is a large supplier of balsa core.
http://www.baltek.com/products/egbc.html
vtec
vtec is offline
Old 03-16-2002 | 06:43 PM
Audiofn's Avatar
Charter Member #232
If I was to guess I would say it is a high density Foam. Could be 12 pound foam perhaps. It is called a couple of different things Like Davinicell and some others that are not coming to my mind right now but lets just say for arguments sake it is foam. If you have not seen the price on this stuff you better sit down it is NOT cheap. I did my transom in Marine Mahogony. The old transom lasted 21 years so all things equall the new one will last much longer. Either way it is WAY longer then I plan on keeping the boat
Audiofn is offline
DonziDog
10-14-2008 08:59 PM
sd11856g
Detailing, Painting, & Fiberglass
0
01-09-2007 10:15 PM
bshzba
3
11-18-2006 11:07 PM
THRILLSEEKER
09-08-2005 05:15 PM
