Cascade to Flush Motors
If you ever get oil in your water on a closed cooling system from a bad oil cooler or heat exchanger it works great to clean the cooling sytem out. Just put in the water and bring the engine up to temp. for a few minutes. Then drain it and refill it with coolant. Milkskake is gone.
It does come in liquid form as well. The good thing would be that it is low sudsing compared to Dawn. Don't know about flushing with it, but it would make sense since since salt is an acid and soap is a base. It would chemically nuetralize the salt.
302Sport
09-19-2008 01:19 PM
32 thunder
07-09-2005 10:09 AM
