Pre-mix fuel in truck?
Ok so here's the question. I have about 150 gallons of 40 to 1 pre-mix 93 octane fuel (from my motion) that I need to find something to do with it. Is it safe to run it in my 2007 Nissan Titan or will the extra oil cause problems with sensors on the engine?
Don
Don
Find your biggest local landscaper and see if they need/want it for their chainsaws, blowers, and weedeaters. You won't get "market" value for it, but they will probably take it for a good compromise.
Don't do it, the o2 sensors and cat will get ruined. you could cut it even more like 2 gal for every 20 you put in and that would be ok. Needs to be like 100-1 before you wouldnt have a problem. But on the other side you truck is under warr. just dont tell them what fuel you run.I would still cut it.
Cut it in half and you'll be fine. I have run out of gas in the work truck many times and had to reach in the back of the truck and put the gallon of pre-mix I have for the demo saws in to get to the gas station.
Anyone have any ideas? I called a local tank cleaning company and they want me to pay 2 dollars a gallon to get rid of it........
