55 Belair Blown Injected On Alky Trade 4 Highend Boat! >
Old 02-03-2009 | 12:20 PM
Default 55 Belair Blown Injected On Alky Trade 4 Highend Boat!
55 CHEVY A/G DOUBLE FRAME RAIL CURRENTLY WITH 7.50 CERT. 511 ALL ALUMINUM RODEX BLOWN INJECTED ON ALKY NEVER WINDOWED LUNATI CRANK BROOK'S RODS JE BLOWER PISTONS CANFIELD HEADS JESEL ROCKERS MANTON PUSH RODS OFF-SET MALLORY MAG 1V JUST FRESHENED NEW 10/71 LITTLEFIELD BLOWER 46% OVERDRIVEN 28-30 PSI BOOST POLISHED BIG & UGLY ENDERLE CAM DRIVEN PUMP NEW RPM DL10 DATALOGGER WITH 8 EGT SENSORS 1 G FORCE,FUEL,OIL,BOOST,DRIVE SHAFT AND RPM. SPEC-RITE BUILT GLIDE DEDENBAR CASE 4/10'S TRANSBRAKE VALVE BODY STRAIGHT CUT 176 HARDEN LOW GEAR RINGLESS AERO SPACE INPUT SHAFT 4500 SPRAGLESS ANTI BALLOONING CONVERTER CHROMOLY 9" 40 SPLINE MOSER AXLE'S 40 SPLINE BILLET SPOOL STRANGE ALUMINUM 3RD MEMBER ANTI-ROLL HARDEN YOLK REAR SHOCK'S R KONI COILOVER'S WITH WILWOOD BRAKES FRONT KONI STRUT'S NEW AR RIM'S FRONT AND BACK WITH TIRE'S WITH ABOUT 6 PASSES 2 SHUTE'S PRO MOD WHEELIE BARS FULL FIRE SYSTEM 2 IN ENGINE COMPARTMENT AND DRIVER HAS C02 TANK THAT WILL CONTROLL LAUNCH RPM WHEN ON THE TRANS BRAKE THE WHOLE CAR IS FRESH ALL THE PAINT AND AIRBRUSH WORK SPEAK'S FOR IT'S SELF! ALL TIN WORK IS FLAWLESS EVERYTHING IS POWDER COATED,POLISHED OR CHROME THIS IS A SHOW QUALITY RACE CAR WITH A CLEAN CA TITLE! TUNED DOWN RIGHT NOW T RUN A GAS #'S 7.60 @185+ ALL DAY LONG!!!! SERIOUS ONLY PLEASE!!! THERE IS NO DISAPOINTMET'S HERE!!!! PIX DO NO JUSTICE FOR THE CAR! IF YOU ARE A PICKY PERSON THIS CAR IS FOR U! OVER $150K INVESTED!!!..........................WILL TRADE 4 BOAT PERFER CAT BUT OPEN TO ALL. FOR PIX E-MAIL [email protected] OR CALL 909 581 0846 THANK'S
fastted is offline
nocigarette
Wanted
4
09-17-2008 02:31 PM
dave54000
2
02-20-2006 08:28 AM
toolman
01-03-2005 08:49 PM
Panther
07-24-2004 02:09 PM
bajah2x105
22
07-16-2002 04:30 PM
