24 monza closed deck (incomplete boat, do not remove add)
24 monza closed deck, (project boat with parts needed to finish do not remove add)
1979 24’ Monza Closed Deck w/dual axle trailer (3,600.00)
do not have time to finish the boat and need money for something else that im working on.
New floor w/reinforced stringer supports and California style / modern dash
New inner transom
Reinforced at hull/deck point all the way around the boat
Custom aluminum color acrylic dash panel w/ monza logo with toggle switches, toggle covers, fuse breakers, and indicator lights.
New nav lights (in box)
New anchor light (in box)
New Courtesy Lights (in box)
New Roll of Duplex Cable for wiring
New terminal blocks (still in box)
New Bilge Pump (in box)
New Float Switch (in box)
New battery Switches (one with key for main power, one without for accesories)
Livorsi Guages with red bezels (also have brand new turquoise bezels)
Chrome 4” Exhaust tips
Misc. parts, helm, radio, wiring for radio, waterproof cover for radio, radio antenna, cables (throttle/shifter) etc. etc.
Bravo I outdrive (1,000.00)
Custom anti-cavitation plate with drive shower
Bobs Nose cone
Fresh gear lube
Freshly Painted
New Mercruiser stickers
454 engine 4bolt main standard bore. (not assembled) (650.00)
Have all pieces needed to rebuild except for intake manifold, gasket set and carburetor
Crank, heads, pistons and block all just came from machine shop
Main and rod bearings brand new still in box
Piston rings brand new still in box.
Recaro Style Bucket Seats (4) (800.00)
Two of them are freshly dyed in silver and have black trim
Two of them are freshly dyed in silver and do not have black trim
Sold as a package deal or separate. If wanting to purchase entire package will give you 1K off price for a total of 5050.00 for everything instead of 6050.00.
You can contact me (Adrian) @ 7863568438
New inner transom
Bobs Nose cone
Fresh gear lube
Freshly Painted
Audiofn
03-10-2004 07:49 PM
