fiberglass sheets
Old 02-03-2009 | 08:57 PM
Fenderjack's Avatar
Pirate of the Chesapeake
Default fiberglass sheets
Thinking of making a new raised hatch.Does anyone make or sell sheets of fiberglass about 1/4" thick.I could cut out my patterns and glass it altogether.Then coat and final sand the thing.Just a thought.Thanks JOHN
Fenderjack is offline
Old 02-03-2009 | 10:46 PM
Use high dens. foam ?! Thats what i would do,,,and bond together with epoxy resin sand and round it all of to where u are happy and then 1 layer of 1808 on each side ,smoth it out again some glass over that ,,,sand again and paint it,,,,thats the best way i know !
DareDevil is offline
Old 02-04-2009 | 07:40 AM
Fenderjack's Avatar
Default fiberglass
Where would I get these sheets, how thick.And you just bond together with fiberglass resin????
Old 02-04-2009 | 08:44 AM
fiberglassservices.com tell them daredevil send you,,they ship nation wide and u can ask him all your questions he has the answers.
Old 02-04-2009 | 03:40 PM
dammmagnum's Avatar
Hi Fenderjack
In the Printed Circuit Board Industry we use laminated E- Glass Sheets , we use small panels sizes,, but the laminate maker, makes sheets up to 5'x 7' size and then cut them down to sizes that we use. Most are copper clad,, but you can get it unclad as bare laminate. Thickness range from 0.001" up to 0.250". At one time they even made color Laminates. they are also vacuum laminated.
Thank you
Jim
dammmagnum is offline
Old 02-04-2009 | 03:48 PM
copiercat's Avatar
its called fiberboard and it comes on a roll and they cut it too the length you need
http://www.fiberglassservices.com/pd...l_2008_web.pdf
copiercat is offline
Old 02-04-2009 | 05:06 PM
Thanks,,,i was actually thinking of the Michigan composit sheets. But i quess the fibersheet would work aswell.
skaterdave
General Racing Discussion
53
01-18-2009 05:28 PM
Scarab3DMC
Wanted
1
07-18-2008 08:33 AM
prosno
03-18-2008 12:19 PM
GregP
3
04-17-2003 02:07 PM
