Prop Selection
First off thanks to Paul from Razors Rdge Performance and Laz from Mesa Balancing.
Basically i'm looking a prop for my V260. I was currently running a 24p Hydro with my 7.4l MPI that decided to have reversion issues that resulted in a new motor.
the motor was dynoed at 560hp with over 500lbs of torque from 3000rpm-5800rpms.
so what i need is help with deciding what prop i should go with..i want something that will plane easily and still run good if i have to carry passangers. the boat doesn't have trim tabs, but i might install later, and yes i do have hydraulic steering.
i'm located in Bermuda and shipping is very expensive and not to mention the 35% import duty that is added as well. FYI it's 55% on all boats and 150% on cars, so i hope u understand my situation.
thanks
q
thanks
q
Crazy Energy
Since you have a prop, try it and see what your numbers are and go from there. I had a single 700hp in a 28' Donzi and ran a 4 blade bravo one 28 pitch. Tabs and Hyd steering would also be a nice safety upgrade.
qaberdeen, I would start off with something in the 28 range. I would also try a Hydromotive prop, they seem to work well on the Velocity.........
Give the factory a call, they would prob. be able to get you pretty close to where you need to be!!
Thanks Fellas for the input. VV i do have the Hyd steering single ram. once the engine arrives, i will post more pics. waiting for the cargo ship to cross d Atlantic. JAB r u running tabs, and just curious how long it takes to get up on plane with passengers with the 30p prop. hers's a few more pics
