chris cat info
Registered User
i just got a 30' chris cat. I've got #3 drives with extension boxes. i installed 900sc that dynoed right at 900 hp could get 1000hp. the motors have been moved 2' forward. what speed will this boat do?
If you're making a LEGIT 900 HP, you'll see more than that. The boat can be weight sensitive, and some of them were potentially heavy (particularly the balsa-cored boats of 1984 and early 1985). Not sure what year you have, and if it is a pleasure or race version. Prop shaft height is also critical: with standoff boxes you would want the prop shaft to be approximately 2" above the bottom of the boat. From the photos, that seems to be about right, but the setback doesn't look like all that much, so it is hard to tell. You may have to play with shaft height.
We had a 1986 full pleasure version with #IV drives on full stand off boxes. With about 800 HP (guesstimate- never dynoed) she saw 112 MPH in a measured kilo run in Key West. My guess is you should see 110-115 with the prop choices that you have available today, maybe more.
Good luck and be safe!
Tom Caruso
Total Marine
Tom Caruso
Total Marine
Cool, i think they are 4's but easy 110 + MPH with the right props , i would go with some 4 blades and 17.5 diameter.
