zinc phosphate outdrive primer ?
i'm going to sandblast and repaint my trs drives, k-planes and water pick up's. they have been chewed up pretty good by corrosion and being 17 years old and in the water all summer doesn't help. i was wondering if anyone has tried that primer ? boat u.s. carries it for 9$ a can. is there a better option? someone suggested a two part epoxy to seal the drives before the anti-fouling paint, also, i think there is a saltwater zink kit for those drives. anybody know where to get it? thanks for the help. Fran
I am getting ready to squirt my drives with Imron. I don't have a corrosion problem, just 14 year old paint that looks crappy. The Imron guy told me to simply scuff the existing paint and spray. Do I need to use self etching primer if I am not going over bare aluminum?
BT
BT
I used the zinc on my transom housings, and an etching primer on my drives. In both cases I used a Sherwin Williams product called "Sunfire" for the color coating. In a few years I should be able to tell you which primer worked best...
EXCALEAGLE, I have been trying to page you after seeing one of your posts. Do you have your old 81 series O/D? I would be interested in any parts you have left. I have a 80 series. I did find a company here in the northwest that has parts and knows where ALL the nos is wharehoused.
thanks Geo 100
thanks Geo 100
geo,
i do have some parts left over, flywheel, clutch, shifter, oil cooler, a solid bronze prop, and other things. the people i was getting parts through was marysville marine in michingan a believe. i think i still have their # if you need it. click on my profile and send me an e-mail if you need some parts or info. i'd be glad to help you out if i can.
