exhaust water shutters >
Old 02-10-2009 | 04:56 AM
Default exhaust water shutters
Does anyone know if i should install exhaust shutters on my thru leg exhaust?
78 Mustang 2400 with V8 sb chev.
Log style exhausts with a 3" riser spacer into y piece.
I have been advised that engine will ingest water when loading / unloading at the ramp.
Any advice much appreciated
Cheers
bustedarse is offline
Old 02-10-2009 | 04:14 PM
I don't have exhaust flaps on mine but you can injest water when unloading. I like the look of my flared exhaust outlets so instead of flaps/shutters I use large rubber bungs(plugs) . These can be connected to the boat by a fine stainless steel cable or similar so they wont get lost if you forget to take them out. The motor will just blow them out once you are in the water and you can pull them up into the boat.
MR.T is offline
Old 02-10-2009 | 05:20 PM
If it hasn't injested water in the last 30 years, I think you'll be ok. Exhaust flappers are designed to keep water out when the boat is not running. Back in slowly at the ramp.
Griff is offline
Old 02-12-2009 | 04:16 AM
Default Thanks guys
Just the advice i needed ...
Thanks guys
frankw32
4
04-18-2008 10:27 AM
frankw32
0
04-17-2008 07:36 AM
k24u
15
05-24-2006 01:07 PM
MILD THUNDER
15
07-27-2005 06:33 PM
ursus
3
12-10-2003 08:32 AM
