fuel pump for carb on gen VI 454
i bought a gen 6 454 and plan to run a carb but there are no provisions for a mechanical fuel pump so i need a electric one. has anyone done this or have suggestions? thanks
I am doing this at the moment,
I'm using a Holley Blue 110GPH fuel pump and regulator but am planning on upgrading to a Barry Grant 220 or 280 pump to feed the engine if I add more Hp later. The Holley Blue or Black will suit your needs unless you're over about 550hp I guess. You'll probably need a regulator though, I was looking at using a Malpasi rising rate regulator to cope with fule demand but the Holley will do for now. What carb / intake are you running?
i think i am grabbing a holley red pump, is it worth the extra cash to get the marine one, all it has is a vacume tap in case the thing burns up. i am running a carter 750 on a edelbrock performer intake, gil manifolds and i am working on a cam. any ideas for a cam??
I don't think a Holley Red will flow enough GPH for your engine at WOT. That's why I went the Holley Blue with the regulator, not too much more money, just better for tuning and peace of mind!
About that cam, everyone to a man on here seems to swear by a guy named Bob Mandara. If you type 'cam' in a search, you'll no doubt find his name about 1000 times. Just find his number and give him a call. I'm under the impression that he is a new age 'Cam Messiah.' He'll set you up right and apparently costs less than most aftermarket options anyway!
But to throw my 2 cents in, I'd vote for the Crane '731' cam to add some life to your set up, but then you'll definitely need the Holley Blue pump!
Best of luck!
Best of luck!
Rage
6
07-31-2007 09:45 AM
GNJ
5
02-07-2006 12:16 PM
