Hammer drunk at low speed >
Old 02-18-2009 | 06:58 PM
teamvortec's Avatar
Default Hammer drunk at low speed
We traded our Fountain this past Christmas for a 2000 Baja Hammer with a 454 mag and Bravo 1. My question is why at a low speed like idleing through a no wake zone the boat pulls from side to side BAD. You actually have to drive the crap out of this thing. I have never seen a boat do this. I have tried trimming motor different and the trim tabs. I am running a 24p 4 blade. I have known this boat since 2001 and it had drove like this since then. Is it just a hammer thing or is there something I can do to correct this?
Thanks,
teamvortec is offline
Old 02-18-2009 | 07:02 PM
Not sure what causes it but mine does the same thing.
Baja_man is offline
Old 02-18-2009 | 07:26 PM
Its called the deep V wobbles.
most do it,
mittens is offline
Old 02-18-2009 | 07:59 PM
My 30 with twins did it. I had to constantly turn the wheel.
redbud35 is offline
Old 02-18-2009 | 08:19 PM
My 99 does the same, its a pain...
HammerJake is offline
Old 02-18-2009 | 08:28 PM
In pleasure boats, B3's cure most of it with the CR props. 4 blades also do a pretty good job at slow speeds, and tabs can help. Have you played with the tabs at all to see if it does help?
VtSteve is offline
Old 02-18-2009 | 08:48 PM
might try trimming up the drive a bit. It always helped mine some.
formulaok is offline
Old 02-18-2009 | 10:58 PM
BAJA WILL's Avatar
Registered User
Speed up,
Actually in all honesty, I think it is bow steering at slow speed, try trimming drive up??
BAJA WILL is offline
Old 02-18-2009 | 11:29 PM
most single engine v hulls hunt at idle speed, helps if you get a lot of seat time, and can somewhat predict when it is going to turn
Perlmudder is offline
Old 02-19-2009 | 04:01 AM
Tabs all the way down will help keep my 24OL straight.
3030hunter is offline
