How to cut carbon fiber panels? >
Old 02-19-2009 | 10:44 AM
Default How to cut carbon fiber panels?
Im considering a company that can make my dash panels for me out of Carbon Fiber. I have two questions though.
1.) is .015" thick enough to support monster gauges? or is that to flimsy?
2.) Will i be able to cut a hole for the gauges using a hole saw still?? or is it too tough?
waterboy222 is offline
Old 02-19-2009 | 11:12 AM
My carbon fiber dash panel is .125 or so.
I would think .015 is a little on the thin side.
A hole saw should be able to cut the panel no problem, I was fortunate enough to get mine cut with a water jet.
Ken
minxguy is offline
Old 02-19-2009 | 11:38 AM
I cut my carbon fiber eng. scoops with a fine jig saw and hole saws, I ran the hole saw in rev. for a sec. to not fra or chip the surface . I then file fit finishing with meg. plastic polish
eliminatethis is offline
Old 02-19-2009 | 01:32 PM
jayhawk261's Avatar
.015" isn't a panel, it's an overlay. I'd think you'd want to be a bit thicker than that.
jayhawk261 is offline
Old 02-19-2009 | 01:45 PM
So the overlay would need to be attached to a metal surface?
Old 02-19-2009 | 01:50 PM
Sean H's Avatar
A to Z
an overlay just goes over another surface (doesnt really matter what)... sounds like you want/need an actual panel, 1/8 should work.
carbon cuts and works with normal tools.
Sean H is offline
Old 02-19-2009 | 06:03 PM
t500hps's Avatar
21 and 42 footers
I just had panels made by Innotech Products and Steve was great to work with. Told me I could cut/work the final panels with normal tools but it wasn't needed.......and that thickness better be an overlay, my panels are over 1/8 thick and strong as chit!!
t500hps is offline
tanner
08-08-2007 09:23 AM
denbo
1
04-25-2004 06:35 PM
Quiet Storm
Sonic
17
03-02-2004 06:50 PM
puder
5
03-11-2003 08:34 AM
Sean
10-18-2002 06:39 AM
